tob1234
openvpn and AES-256-GCM
Thu Apr 22, 2021 11:02 am
According to openvpn the cipher AES-256-GCM is recommended instead of AES-256-CBC. see also here: https://openvpn.net/community-downloads/
My connection gets reset if i use AES-256-GCM when connecting to vpn.
questions:
a) Does mikrotik support ovpn server with the AES-256-GCM cipher ?
b) how to use it in case the answer is "yes"
c) is mikrotik planning to release ovpn with the recommended cipher AES-256-GCM ?
In case the AES-256-CBC is used this gives the following in the vpn logs:
DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-256-CBC' to --data-ciphers or change --cipher 'AES-256-CBC' to --data-ciphers-fallback 'AES-256-CBC' to silence this warning.
environment:
openvpn community client 2.5.2 on windows 10
mikrotik RouterBOARD 962UiGS-5HacT2HnT, version 6.48.1
essides
Re: openvpn and AES-256-GCM
Wed Aug 11, 2021 5:34 pm
same problem here.
any solution?
rextended
Wed Aug 11, 2021 5:42 pm
Consider OpenVPN abandoned.
essides
Wed Aug 11, 2021 5:55 pm
it's amazing, mikrotik has a extremily slow evolution, in few year it will be out of market.
any secure solution for VPN with windows clients?
rextended
Wed Aug 11, 2021 5:59 pm
...in few year it will be out of market...
Is the same phrase someoe wroted on 2010, and nowadays all our core business are on MikroTik machines.
OpenVPN is only a toy.
essides
Wed Aug 11, 2021 6:04 pm
so what do you suggest to implement an strong and easy VPN system for windows clients?
rextended
Wed Aug 11, 2021 6:08 pm
essides
Wed Aug 11, 2021 6:21 pm
With L2tp/Ipsec I have problem when two people over same ip try to connect, one of them is kicked after few time.
I'll read about that. Thanks
rextended
Wed Aug 11, 2021 6:25 pm
I do not write ultra-obsolete PPTP... I hope you never use it anywhere...
Zacharias
AES 256-CBC cipher is not considered strong ?
There is an explanation from @sindy as to why this happens...
There it is :viewtopic.php?t=132823
However this seems to be fixed...
*) l2tp - fixed multiple tunnel establishment from the same remote IP address (introduced in v6.47);
https://mikrotik.com/download/changelogs
So, what is your ROS version ?
essides
Wed Aug 11, 2021 6:36 pm
it's just deprecated for new openvpn client version, I'm not saying that AES 256-CBC is weak
Zacharias
Wed Aug 11, 2021 6:38 pm
It is, but it still works ...
essides
Wed Aug 11, 2021 6:43 pm
but does it has sense to implement something that is deprecated? and half-finished ( no compression/no udp/no new ciphers ) etc..
Zacharias
Wed Aug 11, 2021 6:44 pm
Maybe yes, maybe no... it depends...
bluecrow76
Wed Apr 20, 2022 11:29 pm
For anyone wanting some actual technical information on the issue, this article does a good job of explaining the issue with AES-CBC.
"If you really have no choice and need to use CBC, you can still secure it by computing a message authentication code (MAC) from the ciphertext and IV, this can be done using the popular HMAC algorithm."
A pure OpenVPN server has the ability to add an additional layer of protection using HMAC with the tls-auth configuration option. Most other OpenVPN implementations also support this. Unfortunately when Mikrotik wrote their own OpenVPN implementation supposedly, there are a large number of features that they didn't implement (PUSH options being one glaring omission). tls-auth is another, and because of it, using the methods outlined in the article listed above, a VPN tunnel encrypted with AES-CBC and no HMAC protection is susceptible to attack.
I think OpenVPN was right to deprecate AES-CBC as most people seem to do what's easy and not what's right for one reason or another. It will be interesting to see if Mikrotik gives alternate ciphers to use like AES-GCM in their OpenVPN implementation anytime soon, among other OpenVPN fixes (like returning the event AUTH_FAILED instead of NETWORK_EOF_ERROR when an authentication error occurs so the client will know their credentials are wrong...)
MrDim
Wed May 25, 2022 8:37 pm
So, still no AES-GCM in RouterOS 7?
psztoch
Fri Dec 01, 2023 9:32 pm
No.
Support for AES-256-GCM, AES-128-GCM and CHACHA20-POLY1305 compatible with standard OpenVPN implementation should be added. It is big problem for me.
bluecrow76
Sat Dec 02, 2023 3:38 am
No.
AES-GCM (128/192/256) was added to RouterOS 7.8 in February of 2023 (only after they had added it to just about everything else that uses encryption... :lol:)
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], dioeyandika, raiser, zhenb and 66 guests
