gstubbe
AS-Override on BGP Peer does not change anything to the AS Path
Thu Apr 29, 2021 4:12 pm
I created a small lab setup after a weird issue in our DC. We would like to change the AS path we advertise to our peers. Looking into the options on mikrotik we have the option to "AS-Override" under /routing bgp peer.
Trying that and looking to the received routers on the next router does not remove the extra as numbers from my other peers. I will share a screenshot with my lab setup and their configs.
Setup:
Config - 01
# apr/29/2021 13:08:52 by RouterOS 6.48
# software id =
add name=bridge1
set [ find default-name=ether1 ] disable-running-check=no
set [ find default-name=ether2 ] disable-running-check=no
/routing bgp instance
set default as=65531 redistribute-connected=yes redistribute-static=yes
add address=10.1.1.1/30 interface=ether2 network=10.1.1.0
add address=10.10.1.0/24 interface=bridge1 network=10.10.1.0
/ip dhcp-client
add disabled=no interface=ether1
/routing bgp peer
add name=peer2 remote-address=10.1.1.2 remote-as=65532
/system identity
set name=01
wrong as path on 01:
Config - 02
# apr/29/2021 13:10:29 by RouterOS 6.48
# software id =
add name=bridge1
set [ find default-name=ether3 ] disable-running-check=no
set default as=65532 redistribute-connected=yes redistribute-static=yes
add address=10.1.1.2/30 interface=ether2 network=10.1.1.0
add address=10.1.1.5/30 interface=ether3 network=10.1.1.4
add address=10.10.2.0/24 interface=bridge1 network=10.10.2.0
/ip dhcp-client
/routing bgp peer
add as-override=yes name=peer1 remote-address=10.1.1.1 remote-as=65531
add as-override=yes name=peer3 remote-address=10.1.1.6 remote-as=65533
/system identity
set name=02
Config - 03
# apr/29/2021 13:11:41 by RouterOS 6.48
# software id =
add name=bridge1
set default as=65533 redistribute-connected=yes redistribute-static=yes
add address=10.10.3.0/24 interface=bridge1 network=10.10.3.0
add address=10.1.1.6/30 interface=ether2 network=10.1.1.4
/ip dhcp-client
/routing bgp peer
add name=peer2 remote-address=10.1.1.5 remote-as=65532
/system identity
set name=03
wrong AS path on 03:
Expected behavior would be that all routes on 01 and 02 should be advertised from 65532 and should not include the other as numbers
EDIT: I also test this with public as numbers between 01 and 02 and private as numbers between 02 and 03 with the same result on both 01 and 03
Users browsing this forum: No registered users and 5 guests
