eduardosilva
Help troubleshooting ipv6
Mon May 03, 2021 6:19 pm
Hello there, finally I received ipv6 at my home and decided to learn more about it.
I've followed the advice on this topic: viewtopic.php?t=136994#p674995 and had some "partial success".
Describing my scenario:
2 ISPs connected to my Mikrotik and one LAN.
I'm using bridges for LAN and also each ISP (WAN-1 and WAN-2). Only WAN-2 is working with ipv6.
RouterOS 6.48.2
/ipv6 dhcp-client
add add-default-route=yes interface=WAN-2 pool-name=wan2-poolv6 rapid-commit=no request=prefix
/ipv6 address
add address=::1 advertise=yes from-pool=wan2-poolv6 interface=LAN
/ipv6 settings print
                       forward: yes
              accept-redirects: yes-if-forwarding-disabled
  accept-router-advertisements: yes
          max-neighbor-entries: 8192
/ipv6 nd print
Flags: X - disabled, I - invalid, * - default
 0  * interface=LAN ra-interval=3m20s-10m ra-delay=3s mtu=unspecified reachable-time=unspecified retransmit-interval=unspecified ra-lifetime=30m
      hop-limit=unspecified advertise-mac-address=yes advertise-dns=yes managed-address-configuration=no other-configuration=yes
/ipv6 route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, o - ospf, b - bgp, U - unreachable
 #      DST-ADDRESS              GATEWAY                  DISTANCE
 0 ADS  ::/0                     fe80::1%WAN-2                   1
 1 ADC  2804:aaaa:bbbb:f400::/64   LAN                             0
 2  DSU 2804:aaaa:bbbb:f400::/64                                   1
/ipv6 firewall filter
add action=accept chain=forward
With this configuration, I do receive ipv6 on my internal network. but I can't reach "the v6 internet".
After some testing, I noticed the following (all ipv6 related):
- My lan devices are able to ping each other
- When I try to ping an outside host, I receive timeout.
- I tried to ping google's dns, and watched the result, using torch on LAN interface, I can see my computer sending the ping packets. If I try to run torch on WAN-2 interface, there is no trace of the ping there.
- I've checked the gateway fe80::1%WAN-2 and it does answer correctly on this interface.
- my ipv6 firewall was empty, just in case, I've added an accept to forward and watched the packet count increase after each ping.
Any ideas of where to look?
Thank you!!
Users browsing this forum: itimo01, Laxity, Neojie, yhfung and 30 guests
