shafiqrahman
[Script] Fallback script for DNS traffic redirection using DHCP Server without NAT rules..
Sun May 09, 2021 9:09 pm
This script will act as a fallback mechanism in the scenario where redirected DNS fails. The original idea was
Client --> Mikrotik-->pihole-->Mikrotik as a DNS--> wan
You can find the full development in the original post viewtopic.php?f=2&t=174873&p=856271#p856271
I had difficulties using NAT redirection rules, So, use the /ip dhcp-server network method by @vecernik87 viewtopic.php?t=141616#p698276. Also, because there is no NAT rules so most probably this method will not redirect some apps which have hardcoded DNS. DHCP Server network setup:
add address=192.168.88.0/24 dns-server=192.168.88.5 gateway=192.168.88.1
add address=192.168.88.5/32 dns-server=192.168.88.1 gateway=192.168.88.1
There is only a single issue that is "dhcp changed by" entries in logs. There are two variants, though they are both the same and do the same things.
Script 1
:local gateway "192.168.88.1"
:local currentDNS [/ip dhcp-server network get [find comment=defconf] dns-server]
:local piholeDNS "192.168.88.5"
:local backupDNS ""
:local testDomain "www.google.com"
:if ($currentDNS = $piholeDNS) do={
    :do {
        :resolve $testDomain server $piholeDNS
    } on-error={
        /ip dhcp-server network set 0 address=192.168.88.0/24 dns-server=$backupDNS comment=defconf gateway=$gateway netmask=24;
} else={
    :do {
        /ip dhcp-server network set 0 address=192.168.88.0/24 dns-server=$piholeDNS comment=defconf gateway=$gateway netmask=24;
    } on-error={}
Script 2
:local backupDNS ""
    :do {
    } on-error={
        /ip dhcp-server network set [find comment=defconf] dns-server=$backupDNS;
} else={
    :do {
        /ip dhcp-server network set [find comment=defconf] dns-server=$piholeDNS;
    } on-error={}
shafiqrahman
Re: [Script] Fallback script for DNS traffic redirection using DHCP Server without NAT rules..
Sat May 15, 2021 5:44 pm
These scripts were elegantly enhanced by @2frogs viewtopic.php?f=2&t=174873&p=857287#p856719. So, all credits for this script go to @2frogs. Here is the final code for reference if someone needs it:
:local IPsubnet "192.168.88.0/24"
:local currentDNS
:local alternateDNS "192.168.88.1"
:set $currentDNS [/ip dhcp-server network get [find address=$IPsubnet] dns-server]
:if ($currentDNS=$piholeDNS) do={
    :do {
        :resolve $testDomain server=$piholeDNS
            } on-error={
                /ip dhcp-server network set [find address=$IPsubnet] dns-server=$alternateDNS
} else={
    :do {
        /ip dhcp-server network set [find address=$IPsubnet] dns-server=$piholeDNS
            } on-error={
Users browsing this forum: rextended and 24 guests
