jonah1810
A Better Wireless Auto Frequency Selection
Mon May 10, 2021 5:26 am
Hello, since Mikrotik's frequency=auto is so terrible (it chooses Channel with least amount of AP's Regardless of Signal) I have created one that selects channel based off signal.
My original 2.4ghz script that i posted here was incomplete and as such I have taken it down. In its stead is a 5Ghz script that I am pretty sure has only one flaw and that is if another 5ghz router has channels with 5mhz or 10mhz channel width it wont read through it properly. as it is not possible to set 5mhz or 10mhz channel width in mikrotik routers I can not write it to look for them. I know I have seen 5mhz channels before on a scan with one of my outdoor antennas before though.
so if you are able to get a scan with 5mhz or 10mhz widths please post the file on here so i can alter the script to accommodate for them.
by default the channel exclusion list found three times(one for 20mhz, one for 40mhz, one for 80mhz) in the end section is set for canada country. you must change this setting to comply with your countries frequency regulations
this script requires you to have 5ghz interface named as "wlan2" for people with triband audiences this will only work on 1 of your 5ghz interfaces.
How to use:
1. Select Desired Channel width on wlan2 interface. must be ce or ceee for 40mhz or 80mhz channels respectively
2. /interface wireless wlan2 scan duration=30s save-file=Scan5.rsc
3. Edit Script Exclusions (last part of script) to match your countries frequency regulations.
3. Execute Script.
tested 6.48 (Hapac3)
	:local Scan
	:local ScanLine
	:local LineEnd
	:local Scans [:toarray ""]
	:local ScansSignal
	:local CurrentChannel value=0
	:local Channel [:toarray {5180;5200;5220;5240;5260;5280;5300;5320;5340;5360;5380;5400;5420;5440;5480;5500;5520;5540;5560;5580;5600;5620;5640;5660;5680;5700;5720;5745;5765;5785;5805;5825}]
	:local HighestSignal [:toarray {-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100}]
	:local BestChannel
	:local z value=0
	:local i value=0
	#Set Array Of Scanned AP's CurrentChannel and signal
	:set $Scan value=[/file get Scan5-test.rsc contents]
	while ($z = 0)  do={
		:set $LineEnd value=[find $Scan "\n"]
		:set $ScanLine value=[pick $Scan 0 $LineEnd]
			foreach y in={"802.11";"nstreme";"nv2"} do={
				foreach x in={"/ac";"/an/";"/a/";"/a("} do={
					if ($ScanLine~"$y" && $ScanLine~"$x") do={
						:set ($Scans->$i) value=[:pick $ScanLine ([find $ScanLine ",5"] + 1) [find $ScanLine "$x"]]
						:set $ScansSignal value=[:pick $ScanLine [find $ScanLine ",-"] ([find $ScanLine "$y"] -1)]
		:set ($Scans->$i) value=[($Scans->($i) . ($ScansSignal))]
		:set $Scan value=[:pick $Scan ($LineEnd +1) 999999999]
			if ([:len $Scan] > 20) do={
				:set $i value=($i + 1)
			} else={
				:set $z value=1
		#Find HighestSignal On each channel based on channel width, loops twice to account for newly added channels
	:set $z value=(0)
	while ($z < 2) do={
		foreach k,v in=$Scans do={
			#For Ceee Channels
			if ([:pick [($Scans->$k )] 0 4] = ($Channel->$CurrentChannel) && ([:pick ($Scans->$k) 8 12] = "Ceee")) do={
				if (([:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20] > -100) \
				&& ([:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20] > ($HighestSignal->$CurrentChannel)) \
				&& ([:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20] > ($HighestSignal->($CurrentChannel + 1))) \
				&& ([:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20] > ($HighestSignal->($CurrentChannel + 2))) \
				&& ([:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20] > ($HighestSignal->($CurrentChannel + 3))) \
				) do={
					:set ($HighestSignal->$CurrentChannel) value=[:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20]
					:set ($HighestSignal->($CurrentChannel + 1)) value=[:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20]
					:set ($HighestSignal->($CurrentChannel + 2)) value=[:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20]
					:set ($HighestSignal->($CurrentChannel + 3)) value=[:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20]
			#for eCee
			if ([:pick [($Scans->$k )] 0 4] = ($Channel->$CurrentChannel) && ([:pick ($Scans->$k) 8 12] = "eCee")) do={
				&& ([:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20] > ($HighestSignal->($CurrentChannel - 1))) \
				) do={
					:set ($HighestSignal->($CurrentChannel - 1)) value=[:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20]
			#for eeCe
			if ([:pick [($Scans->$k )] 0 4] = ($Channel->$CurrentChannel) && ([:pick ($Scans->$k) 8 12] = "eeCe")) do={
				&& ([:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20] > ($HighestSignal->($CurrentChannel - 2))) \
				) do={
					:set ($HighestSignal->($CurrentChannel - 2)) value=[:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20]
			#for eeeC
			if ([:pick [($Scans->$k )] 0 4] = ($Channel->$CurrentChannel) && ([:pick ($Scans->$k) 8 12] = "eeeC")) do={
				&& ([:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20] > ($HighestSignal->($CurrentChannel - 3))) \
				) do={
					:set ($HighestSignal->($CurrentChannel - 3)) value=[:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20]
			#For Ce
			if ([:pick [($Scans->$k )] 0 4] = ($Channel->$CurrentChannel) && ([:pick ($Scans->$k) 8 12] = "Ce,-")) do={
				) do={
			#For eC
				&& ([:pick ($Scans->$k) ([find ($Scans->$k) ",-"] +1) 20] > ($HighestSignal->($CurrentChannel - 1 ))) \
				) do={
			#For 20MHZ Wide Channels
			if ([:pick [($Scans->$k )] 0 4] = ($Channel->$CurrentChannel) && ([:pick ($Scans->$k) 5 8] = "20,")) do={
				) do={
		if (([:len $Channel] -1) = $CurrentChannel) do={
			[:set $z value=($z + 1)]
			:set $CurrentChannel value=0
		} else={
			:set $CurrentChannel value=[($CurrentChannel +1)]
	#Select Best Channel Based on Signal, Automatically chooses channelwidth based off of currently set channel width
	#Default Setting is for Canada country setting, Skipping DFS Channels but you can change the excluded channels lists to fit your needs
	#You must change the excluded channel in whichever channel-width you want to suit your needs in the script below, or all three.
	:local Bool
	if ([/interface wireless get wlan2 channel-width] = "20mhz") do={
		foreach k,v in=$HighestSignal do={
			set $Bool value="true"
			foreach x,i in=$Channel do={
	# add Exclusion Channels on second line from here ie."&& $k != 1" 0=5180 1=5200...etc
				if (($v <= ($HighestSignal->$x))&& ($Bool = "true") \
				&& ($k != 7 && $k != 8 && $k != 9 && $k != 10 && $k != 11 && $k != 12 && $k != 13 && $k != 14 && $k != 15 && $k != 16 && $k != 17 && $k != 18 && $k != 19 && $k != 20 && $k != 21 && $k != 22 && $k != 23 && $k != 24 && $k != 25 && $k != 26) \
				) do={
					:set $Bool value="true"
				} else={
					:set $Bool value="false"
			if ($Bool = "true") do={
				:log warning message=($Channel->$k)
				:set $BestChannel value=($Channel->$k)
		/interface wireless set wlan2 frequency=$BestChannel
	if ([/interface wireless get wlan2 channel-width] = "20/40mhz-Ce") do={
	# add Exclusion Channels on second line from here ie "&& $k != 1" 0=5180 1=5200...etc
				if (($v <= ($HighestSignal->$x)) && (($HighestSignal->($k + 1)) <= ($HighestSignal->$x)) && ($Bool = "true") \
				&& ($k != 7 && $k != 8 && $k != 9 && $k != 10 && $k != 11 && $k != 12 && $k != 13 && $k != 14 && $k != 15 && $k != 16 && $k != 17 && $k != 18 && $k != 19 && $k != 20 && $k != 21 && $k != 22 && $k != 23 && $k != 24 && $k != 25 && $k != 26 && $k != 31) \
				) do={
				} else={
	if ([/interface wireless get wlan2 channel-width] = "20/40/80mhz-Ceee") do={
			if (($v <= ($HighestSignal->$x)) && (($HighestSignal->($k + 1)) <= ($HighestSignal->$x)) && (($HighestSignal->($k + 2)) <= ($HighestSignal->$x)) && (($HighestSignal->($k + 3)) <= ($HighestSignal->$x)) && ($Bool = "true") \
			&& ($k != 5 && $k != 6 && $k != 7 && $k != 8 && $k != 9 && $k != 10 && $k != 11 && $k != 12 && $k != 13 && $k != 14 && $k != 15 && $k != 16 && $k != 17 && $k != 18 && $k != 19 && $k != 20 && $k != 21 && $k != 22 && $k != 23 && $k != 24 && $k != 25 && $k != 26 && $k != 29 && $k != 30 && $k != 31) \
			) do={
			} else={
jonah1810
Re: A Better Wireless Auto Frequency Selection
Sat Jun 12, 2021 9:48 am
added complete 5ghz script and removed 2.4ghz script. will update with a complete version soon.
Jotne
Sat Jun 12, 2021 10:43 am
Do you need all variable to be global? if not use local.
Here it the same version but with tab for all groups. (gives better reading)
:log warning message=[:time {
	:global Scan
	:global ScanLine
	:global LineEnd
	:global Scans [:toarray ""]
	:global ScansSignal
	:global CurrentChannel value=0
	:global Channel [:toarray {5180;5200;5220;5240;5260;5280;5300;5320;5340;5360;5380;5400;5420;5440;5480;5500;5520;5540;5560;5580;5600;5620;5640;5660;5680;5700;5720;5745;5765;5785;5805;5825}]
	:global HighestSignal [:toarray {-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100;-100}]
	:global BestChannel
	:global z value=0
	:global i value=0
	:set $Scan value=[/file get Scan5.rsc contents]
	while ($z = 0)  do={
	if ($ScanLine~"802.11") do={
		if ($ScanLine~"/ac") do={
			:set ($Scans->$i) value=[:pick $ScanLine ([find $ScanLine ",5"] + 1) [find $ScanLine "/ac"]]
		if ($ScanLine~"/an/") do={
			:set ($Scans->$i) value=[:pick $ScanLine ([find $ScanLine ",5"] + 1) [find $ScanLine "/an"]]
		if ($ScanLine~"/a/") do={
			:set ($Scans->$i) value=[:pick $ScanLine ([find $ScanLine ",5"] + 1) [find $ScanLine "/a/"]]
		if ($ScanLine~"/a(") do={
			:set ($Scans->$i) value=[:pick $ScanLine ([find $ScanLine ",5"] + 1) [find $ScanLine "/a("]]
			:set $ScansSignal value=[:pick $ScanLine [find $ScanLine ",-"] [find $ScanLine ",802.11"]]
	if ($ScanLine~"nv2") do={
			:set $ScansSignal value=[:pick $ScanLine [find $ScanLine ",-"] [find $ScanLine ",nv2"]]
	if ($ScanLine~"nstreme") do={
		if ($ScanLine~"/ac/") do={
			:set ($Scans->$i) value=[:pick $ScanLine ([find $ScanLine ",5"] + 1) [find $ScanLine "/ac/"]]
			:set ($Scans->$i) value=[:pick $ScanLine ([find $ScanLine ",5"] + 1) [find $ScanLine "/an/"]]
		:set $ScansSignal value=[:pick $ScanLine [find $ScanLine ",-"] [find $ScanLine ",nstreme"]]
	} else={
	:set $z value=1}
	# Find HighestSignal Signal On each channel based on channel width, loops twice to account for newly added channels
	:set $z value=(0)
	while ($z < 2) do={
			#For Ceee Channels
				) do={
			#for eCee
				) do={
			#for eeCe
				) do={
			#for eeeC
				) do={
			#For 40Mhz Wide Channels
				) do={
				) do={
		} else={
	:global Bool
				# add Exclusion Channels here on second line ie from here"&& $k != 1" 0=5180 1=5200...etc
				) do={
				} else={
				# add Exclusion Channels here on second line from here ie "&& $k != 1" 0=5180 1=5200...etc
				) do={
				} else={
				) do={
				} else={
Try Splunk> to monitor your MikroTik Router(s). How to set it up. :mrgreen:
MikroTik->Splunk
jonah1810
Sat Jun 12, 2021 10:56 am
oops, i forgot to change that back, i only had it global to easily read values in winbox!
Jotne
Sat Jun 12, 2021 11:02 am
It seems that it may be shorten some, like
Looks equal, and may be shorten to run one group test 3 times with different input instead of 3 different group test.
Example
foreach i in=[:toarray "802.11,nv2,nstreme"]  do={:put $i}
MikroTik->Splunk
Jotne
Sat Jun 12, 2021 4:41 pm
you must create a scan file called "Scan5.rsc" with preferably a full scan-list of 5180-5825.
How? I do not understand what to do to create the file.
Here is a re post with correct tabs. (you have a mix of spaces and tabs in front of lines, makes i hard to see each section.)
:local Scan
:local ScanLine
:local LineEnd
:local ScansSignal
:global BestChannel
:global z value=0
:global i value=0
while ($z = 0)  do={
	} else={
		:set $z value=1
:set $z value=(0)
while ($z < 2) do={
		#For Ceee Channels
			) do={
		#for eCee
			) do={
		#for eeCe
			) do={
		#for eeeC
			) do={
			) do={
			) do={
	} else={
:global Bool
			) do={
			} else={
			) do={
			} else={
			) do={
			} else={
Could not this part:
be shorten to?
	if ($ScanLine~"(802.11|nv2|nstreme)") do={
MikroTik->Splunk
rextended
Sat Jun 12, 2021 7:29 pm
<tag>
jonah1810
Sat Jun 12, 2021 11:56 pm
Jotne use the command:
While i cant do what you suggest in your newest post because of the line
":set $ScansSignal value=[:pick $ScanLine [find $ScanLine ",-"] [find $ScanLine ",nstreme"]]"
I was able to shorten it down into 2 foreach loops. I edited the OP to have the changes!
I like how you refactored the script to make it more readable but for some reason it stops working when I use the refactored version.
Jotne
Sun Jun 13, 2021 8:56 am
You cant change to use an variable?
:set $ScansSignal value=[:pick $ScanLine [find $ScanLine ",-"] [find $ScanLine $i]]
You are still mixing space and tabs in front of lines. And you do miss tabs for several groups.
Every time some starts with {, rest should be tabbed in one
MikroTik->Splunk
jonah1810
Sun Jun 13, 2021 10:18 am
Well that is exactly what I am doing now. I just mean i cant use
because it will come back true and and then
will have a chance of setting a blank variable instead of the signal. depending on which variable was last in loop.
but the nested foreach loops work just fine and are much neater than what I had before!
I refactored it aswell so it is easier to read.
Jotne
Sun Jun 13, 2021 3:55 pm
I did not tell you to put all in one if, that will not work, but run it 3 times
	some code
		if ($ScanLine~$i) do={
			:set $ScansSignal value=[:pick $ScanLine [find $ScanLine ",-"] ([find $ScanLine "$i"] -1)]
MikroTik->Splunk
Users browsing this forum: rextended, roemer and 16 guests
