akmodi
MIKROTIK RB911G-2HPND, Maximum speed possible
Mon May 10, 2021 6:30 am
Just a quick basic question: what is the theoretical maximum that can be achieved with 2 of these boards, 21dbi antennae. Lets say at 100m, clear LOS. Thanks
honzam
Re: MIKROTIK RB911G-2HPND, Maximum speed possible
Mon May 10, 2021 11:01 pm
Why 2,4Ghz? On 100m link you can use 60Ghz = 1Gbit troughput
LAN, FTTx, Wireless. ISP operator
bpwl
Mon May 10, 2021 11:18 pm
https://mikrotik.com/product/RB911G-2HPnD
Wireless specification.
300Mbps is the "interface rate" ! See http://mcsindex.com/ , yellow field, 40 MHz bandwidth (use only if you are alone there!), dual stream, MCS15, SGI=short guard interval of 0.4µs)
Practical throughput could be 200Mbps for UDP, 150 Mbps for TCP. Overhead depends on the buffer size used.
Available airtime will not be 100% if other 2.4GHz devices are around. And also the quality (CCQ) will be reduced by noise and interference, what will make the devices lower the MCS rate used.
rextended
Tue May 11, 2021 12:31 am
+1000
If you don't have buy any, buy 60GHz... less size, more speed...
akmodi
Tue May 11, 2021 1:37 pm
Thanks All, esp Bpwl.
Users browsing this forum: Bing [Bot] and 25 guests
