allevotp
L2TP/IPSEC MikroTik Server and Cisco Router Client
Tue May 11, 2021 12:30 pm
I need to configure a L2TP/IPSEC between a Router Cisco (client) and a MikroTik (server). I get the tunnel UP but without IPSEC, when I want to configur it with IPSEC the tunnel won't come up.
The error that I can see on MikroTik's logs is "X.X.X.X (public ip remote) ignore the packet, received unexpecting payload type 15".
The router Cisco has a public IP and the MikroTik too.
The configuration is:
Router Cisco:
pseudowire-class L2TP_PW
 encapsulation l2tpv2
 ip local interface FastEthernet0/1
crypto isakmp policy 1
 encr aes 256
 group 2
 lifetime 1800
crypto ipsec transform-set ESP-AES-256 esp-aes 256 esp-sha-hmac
 mode transport
crypto isakmp key X.X.X.X (IPSEC SECRET) address X.X.X.X (MikroTik's Public IP)
crypto map L2TPMAP 1 ipsec-isakmp
 set peer X.X.X.X (MikroTik's Public IP)
 set transform-set ESP-AES-256
 match address L2TP-IP
 description IP Publica
 ip address X.X.X.X X.X.X.X (Cisco's Public IP)
 load-interval 30
 duplex auto
 speed auto
 crypto map L2TPMAP
interface Virtual-PPP1
 description L2PT Tunnel
 ip address negotiated
 ip pim sparse-dense-mode
 ip igmp query-interval 125
 load-interval 30
 no cdp enable
 ppp chap hostname X.X.X.X (Username of L2TP)
 ppp chap password X.X.X:X (Password of L2TP)
 ppp ipcp address accept
 pseudowire X.X.X.X 1 pw-class L2TP_PW (MikroTik's Public IP)
ip access-list extended L2TP-IP
 permit ip host X.X.X.X (Cisco's Public IP) host X.X.X.X (MikroTik's Public IP)
Between MikroTiks is working, not working only between Cisco and MikroTik. Do you know what happens?
Thanks a lot,
arnaucda
Re: L2TP/IPSEC MikroTik Server and Cisco Router Client
Wed May 12, 2021 12:17 pm
I have the same problem. If someone know the solution I would really appreciate it.
Thanks!
allevotp
Fri May 21, 2021 10:11 am
Has it happened to anyone? or that you can share your configuration that is working with L2TP / IPSEC.
Thanks!
jatoledano
Sun Feb 05, 2023 10:58 pm
I made it work changing the lines to
crypto isakmp policy 5
encr 3des
authentication pre-share
group 2
Users browsing this forum: Amazon [Bot], Bing [Bot], ericksetiawan, JDF and 90 guests
