bschooly
Removing queue via API
Mon May 17, 2021 5:26 pm
I'm trying to remove a simple queue. I first do a print with a filter on target to get the desired queue record. Then I simply do:
/queue/simple/remove
=.id=*7
where *7 is what was returned from the print result's .id value. Results are:
!done
Yet, the queue remains. What am I doing wrong?
rextended
Re: Removing queue via API
Tue May 18, 2021 1:07 am
I do not know if on API is like on terminal but:
"print ID" <> .id
0, 1, 2, 3, 4 <> *2, *6, *7a, *80, *9f
print list order <> internal database .id
you try to delete dynamic queue?
bschooly
Re: Removing queue via API  [SOLVED]
Tue May 18, 2021 1:27 am
OOPS. Problem was in use of API. I was "consuming" the results of the print command with a readSentence when it should have been readBlock. This no doubt left the i/o out of sync when I executed the remove command. So problem resoled.
Users browsing this forum: No registered users and 20 guests
