David1234
how to PCC in version 7?
Tue May 18, 2021 12:53 pm
Hello
up until now I have used pcc load balancing in mikrotk version 6.45 with 2 sims
work without any problems .
I have upgrage to version 7 in order to use the quectel modem as LTE interface
but it doesn't work
when I try to setup my working configuration from start , I see the problem is in this part
/ip firewall mangle
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
    in-interface=Local new-routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=SIM1 routing-mark=to_WAN1
I get this error:
input does not match any value of new-routing-mark
waht is cahnge in version 7? what is the "new" command I need to put? and how do I make this works?
Thanks ,
mrz
Re: how to PCC in version 7?
Tue May 18, 2021 2:38 pm
lilw
Wed Dec 08, 2021 11:28 am
Today I upgraded to v7.1 and find out my network can't access internet with my route config. After a while with some suggestion around this forum, I find that I will need to fix the route, add 2 rules to the route/rules, edit the routes table without ping in check gateway. So it actually works right now.
chrisarzu
Tue Feb 22, 2022 4:35 pm
Running RouterOS 7.2rc3, set up PCC and it's working, but a major issue I have is that the router itself cannot go out on the internet
Notice below that I added 4 routes, 2 in the main table, and 1 for each routing mark.
PCC works fine only when the 2 default routes in the main table are disabled on purpose, if I enable them, the router is able to go out the internet, but PCC stops working.
I am missing something, but not sure what is is, so a little help would be appreciated.
model = RBD52G-5HacD2HnD
add disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=192.168.133.1 pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=192.168.123.1 pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.123.1@main pref-src=0.0.0.0 routing-table=WAN1toISP1 scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.133.1@main pref-src=0.0.0.0 routing-table=WAN2toISP2 scope=30 suppress-hw-offload=no target-scope=10
***************Below is the rest of the relevant config****************
/routing table
add fib name=WAN1toISP1
add fib name=WAN2toISP2
/ip firewall mangle
add action=mark-connection chain=prerouting dst-address-type=!local in-interface-list=LAN new-connection-mark=WAN1Conn passthrough=yes per-connection-classifier=both-addresses:2/0
add action=mark-connection chain=prerouting dst-address-type=!local in-interface-list=LAN new-connection-mark=WAN2Conn passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1Conn dst-address-type=!local new-routing-mark=WAN1toISP1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2Conn dst-address-type=!local new-routing-mark=WAN2toISP2 passthrough=yes
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=ether1WAN1
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=ether2WAN2
moutazsalem
Sat Mar 26, 2022 4:36 pm
/routing table
/ip firewall mangle
I have the same exact issue, in addition, failover is not working as well, any help would be appreciated
i followed the instructions here https://help.mikrotik.com/docs/display/ ... mple3(PCC)
moutazsalem
Tue Apr 26, 2022 4:28 am
got it sorted out, now the router has access, PCC is working, also failover is fine
/routing table
add fib name=to_WAN1
add fib name=to_WAN2
/ip firewall mangle
add action=accept chain=prerouting dst-address=192.168.50.0/24 in-interface=LAN
add action=accept chain=prerouting dst-address=192.168.60.0/24 in-interface=LAN
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=WAN1 new-connection-mark=WAN1_conn
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=WAN2 new-connection-mark=WAN2_conn
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=LAN new-connection-mark=WAN1_conn per-connection-classifier=both-addresses:2/0
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=LAN new-connection-mark=WAN2_conn per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn in-interface=LAN new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn in-interface=LAN new-routing-mark=to_WAN2
add action=mark-routing chain=output connection-mark=WAN1_conn new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn new-routing-mark=to_WAN2
add disabled=no distance=1 dst-address=161.35.244.216/32 gateway=192.168.50.1 routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=188.166.105.4/32 gateway=192.168.60.1 routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add distance=1 gateway=192.168.50.1 routing-table=to_WAN1
add distance=2 gateway=192.168.60.1 routing-table=to_WAN1
add distance=1 gateway=192.168.60.1 routing-table=to_WAN2
add distance=2 gateway=192.168.50.1 routing-table=to_WAN2
Peyoz
Sun Jun 05, 2022 1:05 pm
Same issue here, 2 LTE WAN interfaces and whenever I'm adding a default route for the router itself, PCC stops working.
Sorry, but this solution does not work with LTE interfaces
Users browsing this forum: No registered users and 21 guests
