indnti
CRS326-24S+2Q - SNMP Temperatur Monitoring
Wed Jun 16, 2021 4:59 pm
Hi
On one of our five CRS326-24S+2Q the device temperature can be monitored via SNMP (Zabbix) since ROS 6.48.3. On the other 4 CRS it is "not supported".
They have the same newest Router OS, the same Firmware (6.48.3), the same firmware type (qca9531L) and the SNMP settings on the monitoring server are the same.
The only difference is, that the 326 where the device temperature can be retrieved is a litte bit newer, maybe a half year.
If I filter on the Mikrotik hardware site on "Temperature Sensor" the CRS326 isn't shown.
Does this make any sense?
rextended
Re: CRS326-24S+2Q - SNMP Temperatur Monitoring
Wed Jun 16, 2021 7:22 pm
[rextended@Gateway] > sys he pri oid
         active-fan: .1.3.6.1.4.1.14988.1.1.3.9.0
            voltage: .1.3.6.1.4.1.14988.1.1.3.8.0
            current: .1.3.6.1.4.1.14988.1.1.3.13.0
        temperature: .1.3.6.1.4.1.14988.1.1.3.10.0
    cpu-temperature: .1.3.6.1.4.1.14988.1.1.3.11.0
  power-consumption: .1.3.6.1.4.1.14988.1.1.3.12.0
yes, version revision happen...
if is present a /r2 on the end of serial, are second release, if is not present any /r are first,
/3 is the third, and so on...
indnti
Fri Jun 18, 2021 11:23 pm
All CRS326 serves out the device temperature on OID .1.3.6.1.4.1.14988.1.1.3.100.1.3.14, but only the newer supports OID .1.3.6.1.4.1.14988.1.1.3.10.0
Users browsing this forum: No registered users and 74 guests
