wahrheitb
OSPF second area
Thu Jun 17, 2021 6:05 pm
Hello everyone,
with GNS3 I have simulated a small network area that also causes problems on a large scale. the ROS version used is 6.48.3, which is the latest stable. The problem occurs when I set up a second OSPF area on the Mikrotik (CHR3). Then no more OSPF routes can be found via "ip route print", but the routes are still listed via "routing ospf lsa print". As soon as I remove the second area, the routes are back.
If I replace the Mikrotik with a Cisco, the problem does not exist and everything works.
Here the configs.
CHR1
/routing ospf instance
set [ find default=yes ] distribute-default=if-installed-as-type-1 \
    redistribute-connected=as-type-1
add address=10.0.0.1/30 interface=ether2 network=10.0.0.0
/ip dhcp-client
add !dhcp-options disabled=no interface=ether1
/routing ospf network
add area=backbone network=10.0.0.0/30
/system identity
set name=CHR1
CHR2
/routing ospf area
add area-id=0.0.0.10 name=area10
    redistribute-connected=as-type-1 router-id=10.0.0.2
add address=10.0.0.2/30 interface=ether1 network=10.0.0.0
add address=10.10.0.1/24 interface=ether2 network=10.10.0.0
add area=area10 network=10.10.0.0/24
/routing ospf virtual-link
add neighbor-id=10.10.0.6 transit-area=area10
/system identity
set name=CHR2
CHR3
/routing ospf area
add area-id=0.0.0.20 name=area20
set [ find default=yes ] redistribute-connected=as-type-1 router-id=10.10.0.6
add address=10.10.0.6/24 interface=ether1 network=10.10.0.0
add address=5.5.5.5/24 interface=ether2 network=5.5.5.0
add area=area20 network=5.5.5.0/24 # when is removed then i can see the OSPF routes "ip route print"
add neighbor-id=10.0.0.2 transit-area=area10
/system identity
set name=CHR3
CHR4
/routing ospf area
add address=5.5.5.1/24 interface=ether1 network=5.5.5.0
/system identity
set name=CHR4
here an screenshot with
and without the OSPF network entry
JJT211
Re: OSPF second area
Fri Jun 18, 2021 5:49 am
On all routers set
redistribute-connected=no
Im new to OSPF but I believe in most cases, you should only distribute routes by the network tab. Leave everything set to no with the exception of the default route
CHR1 for example, should look like this
/ip dhcp-client
/system identity
set name=CHR1
millenium7
Long time Member
Long time Member
Wed Jul 14, 2021 6:26 am
What you are posting violates the operational rules of OSPF and will not work properly
OSPF requires all area's to directly connect to the backbone/Area0
In your example, area 20 is not connected to area 0
You can bend this rule with 'virtual links' to form a tunnel between area0 and area20, however this is not recommended and will not result in the type of traffic flow you would logically expect
In order for area20 to talk to area10 for instance, it will traverse Area20->Area0->Area10
......... Yes OSPF design absolutely sucks in many networks
There are valid reasons behind its design concepts, but the simple reality is they don't fit all networks, period. Despite what some rigid people seem to think
The 'best' solution (i'd argue 'totally shit', but you have to work within the design boundaries) is to simply not use different area's whatsoever. Leave everything in Area0, otherwise it causes issues with things like MPLS/VPLS and becomes an administrative nightmare if a sectioned off area starts to grow beyond what you think, or you need redundant paths that lead back to Area0 (maybe through another area like you've created a ring network) yada yada yada
There are networks with 500+ routers all in a single backbone area and it works. Is it ideal? not at all, but its the lesser evil
Users browsing this forum: No registered users and 45 guests
