wintech2003
Routers behind SSTP tunnel not reachable
Mon Jun 21, 2021 12:31 pm
I have two routers, R1 and R2, connected via SSTP as per the following diagram.
R1 has a switch connected, and on that switch are servers with IPs in the 10.0.0.0/24 subnet.
R2 has a switch connected with servers in the 10.10.1.0/24 subnet, as well as two other routers, R3 & R4 with IP 10.10.1.240 and .241 respectively.
The interfaces on which the switch and two routers are connected are setup as a bridge.
I have created the necessary static routes in R1 and R2, so that the two subnets can communicate over the SSTP tunnel.
Now, the problem is that I can not reach the R3 & R4 from the other side of the tunnel.
Ping from R2 to R3 & R4 & vice versa works fine.
Ping from R3 & R4 to servers at 10.10.1.0/24 works fine.
Ping from R2 to servers at 10.10.1.0/24 works fine.
Ping from R1 to R2 works fine.
Ping from R1 to servers at 10.10.1.0/24 works fine.
Ping from servers at 10.0.0.0/24 to servers at 10.10.1.0/24 works fine.
Ping from R1 to R3 & R4 does not work.
Ping from servers at 10.0.0.0/24 to R3 & R4 does not work.
Any ideas?
mikeeg02
Re: Routers behind SSTP tunnel not reachable
Mon Jun 21, 2021 2:55 pm
Simplistic fix is to enable proxy-arp on the bridge on R2 that the R3,R4, etc connect through. In my opinion the better approach is to put the sstp tunnel traffic on a subnet different than that the client's use.
wintech2003
Mon Jun 21, 2021 7:54 pm
But it is.
Servers in R1 side are at 10.0.0.0/24
The tunnel is in 10.0.1.0/24
Servers in R2 side are at 10.10.1.0/24
Setting the bridge ARP setting to proxy-arp on R2 didn't help unfortunately :(
mikeeg02
Tue Jun 22, 2021 6:09 am
My apologies, I was a little dyslexic with some of the numbers.
Re-reading what isnt working, it sounds like R3, and R4 need either the gateway put into them, or a static route also entered into them for the 10.0.0.x/24 subnet and utilizing the 10.10.1.254 gateway.
As you said, R1 and servers 10.0.0.x/24 to the servers at 10.10.1.x/24 works, so the sstp tunnel is working.
But it would appear that routers R3, and R4 do not have the proper gateway or static route also put into them.
Users browsing this forum: johnson73, onnyloh, sindy and 147 guests
