sahinms
S+RJ10 turns itself off due to overheating
Fri Jul 02, 2021 10:34 am
I have S+RJ10 and CRS326-24G-25+RM products. Although the 10g module is not used, its temperature rises and turns itself off for 10 minutes. It turns off again about 16 minutes after it is turned on. it goes on like this all the time. The interesting thing is that I removed this port from network use because of these breaks, only its cable is plugged in.
msatter
Re: S+RJ10 turns itself off due to overheating
Fri Jul 02, 2021 1:37 pm
Not much new: viewtopic.php?f=3&t=132258&p=862859&hil ... ot#p862859
Using fiber is a cooler solution if possible.
msatter
Not much new: viewtopic.php?f=3&t=132258&p=862859&hil ... ot#p649631
sahinms
Fri Jul 02, 2021 2:26 pm
ok but what about this purchased product
msatter
Fri Jul 02, 2021 4:15 pm
Sorry for the double post.
The product page of the SFP states: "S+RJ10 module is supported also on devices with passive cooling, but may require an extra cooling."
Source: https://mikrotik.com/product/s_rj10
Yours may be defective but these boys are know that you fry eggs on them....very small eggs.
mada3k
Long time Member
Long time Member
Fri Jul 02, 2021 4:54 pm
S+RJ10 unfortunally gets insanley hot. 89 degress is just way to hot to function properly.
mbovenka
Fri Jul 02, 2021 6:18 pm
Last summer, when it got close to 40C around here, the two S+RJ10s I have in use (one in a CRS309 and another in a RB4011, both passively cooled devices) reached 100C and lived to tell the tale. They didn't even switch off; just soldiered on.
But I second the use of fiber if at all possible. Lots cheaper and lots cooler.
Users browsing this forum: No registered users and 34 guests
