kbch
Kernel Crash when adding WG Peer 7.1beta6
Fri Jul 02, 2021 10:53 am
Hello
I'm trying to configure a Wireguard connection with 7.1beta6 on CCR1009-8G-1S-1S+. But always after adding the Peer it crashes.
The Interface can be configured without issues:
[admin@MikroTik] > /interface wireguard print
Flags: X - disabled; R - running
 0  R name="rbg0" mtu=1420 listen-port=5037 private-key="xxx"
But after adding a Peer it crashes after a few seconds:
[admin@MikroTik] > /interface wireguard peers add interface=rbg0 endpoint-address=xx.xxx.xxx.xx endpoint-port=51820 persistent-keepalive=25 public-key="xxx" allowed-address=192.168.99.0/24
[admin@MikroTik] > packet_write_wait: Connection to 172.16.90.104 port 22: Broken pipe
It then beeps and I can login again. After Logging in it reports a Kernel failure (and crashes again after a few seconds until I remove the Wireguard peer):
jan/02/1970 01:00:10 system,error,critical router was rebooted without proper shutdown, probably kernel failure
jan/02/1970 01:00:10 system,error,critical kernel failure in previous boot
kbch
Re: Kernel Crash when adding WG Peer 7.1beta6
Fri Jul 02, 2021 11:41 am
I just tried it with the Cloud Hosted Router Image, also version 7.1beta6, with the exact same Configuration. With the Cloud Hosted Router Image I don't get a Kernel Crash. Can someone from Mikrotik confirm this Bug?
kiler129
Sat Jul 03, 2021 11:58 pm
Are you observing this in a fresh install too or did you upgrade from previous betas? There was a change in peers format in I believe beta 5.
kbch
Sun Jul 04, 2021 1:34 pm
This device was directly upgraded from 6.47 to 7.1beta6. Thus, also the Wireguard configuration was made on 7.1beta6.
kbch
Sun Jul 04, 2021 4:55 pm
I've now performed a Reset Configuration and afterwards ran my two WG config commands again. This time WG is working without Kernel Crash. I have no explanation for this. Maybe something weird happened during Update 6.47->7.1beta6 which prevented WG to work.
kiler129
Sun Jul 04, 2021 11:17 pm
In general it's understood that the raw configuration format is not stable in beta. If I have to guess developers are only testing upgrade between the newest v6 (i.e. not the stable one) and newest v7.
wgrando1993
Tue Dec 21, 2021 1:26 pm
Hi dear, same problem here, but only in TILE architecture !
tested in arm, mipsbe, mipsle and work fine !
sledzik1984
Mon May 02, 2022 2:04 pm
Same for me.
Wireguard crashing with kernel panic CCR-1009-8G-1S-1S+ (Tile) with RouterOS 7.2.1
Users browsing this forum: No registered users and 55 guests
