Equis
Forum Veteran
Forum Veteran
What is more reliable
Wed Aug 08, 2007 7:08 am
Hello
is rb133 more reliable than the rb153 with 3 wireless cards?
normis
Re: What is more reliable
Wed Aug 08, 2007 9:32 am
I don't think there is much difference, they are the same platform and CPU, just different number of interfaces
natedogg104
Mon Aug 13, 2007 8:14 am
id say the more things that you use on the routerboard as in services and or cards the more unstable either will be, so if you use the one that has more interfaces and you put more services on it then the one that is being used more could be a lil less stable as in cpu usage/ memory/ hdspace will go up
Users browsing this forum: No registered users and 79 guests
