dhiaahmed
script scheduler
Fri Jul 09, 2021 11:55 am
Hello everyone, I have a script and I need it to be run between two specific times for example, between 23:00:00pm to 05:00:00. I couldn't do that in mikrotik scheduler. Is there a way to do this?
rextended
Re: script scheduler
Fri Jul 09, 2021 12:00 pm
Be more clear, also on topic title: "script scheduler", what?
Set it to 3am do not suffice?
msatter
Fri Jul 09, 2021 12:39 pm
You have to generate a random time in the scrip you schedule. Then use that delay to wait that random time before executing the rest of the script.
The only thing random in ROS is OTP in Certificates.
dhiaahmed
Fri Jul 09, 2021 12:54 pm
what I mean is I want the script to be run form 23:00:00 pm to 05:00:00 am with 00:15:00 interval after that I don't want it to be run utile 23:00:00 pm the next day. can I do it with
/system scheduler
rextended
Fri Jul 09, 2021 2:00 pm
I haved also think that (random execution), but I have prefered to ask....
False, and overcomplicate,
search my post for random numbers.
viewtopic.php?f=9&t=175453&p=858629
rextended
Fri Jul 09, 2021 2:03 pm
Why you do not provide this details at start?
Schedule a scheduler al 23:00 than schedule the activation of the other scheduler, scheduled every 15 min,
and schedule another scheduler at 05:00 to disable the scheduled scheduler every 15 min.
Or more simply check at the start, inside the scheduled script, if the time are between 23:00 and 05:00
dhiaahmed
Sat Jul 10, 2021 2:24 pm
Thank you so much for your fast replies, would you please check if this script is correct because I don't have much experience in writing scripts:
global tm 23:00:00;;
global nt [system clock get time];
if ($nt >= 23:00:00 || $nt <= 05:00:00) do={system scheduler enable [find where name=night];system scheduler disable [find where name=sharing] } else={system scheduler disable [find where name=night];system scheduler enable [find where name=sharing]}
rextended
Re: script scheduler  [SOLVED]
Sat Jul 10, 2021 3:15 pm
You have mixed the 2 proposed solution,
1st solution without complicated scripts:
You can do copy & paste, the scripts are ready if your other scheduers are really called "night" and "sharing"
Supposing that "nigth" and "sharing" are another two scheduler scheduled every 15 minutes.
Create one scheduler than at 23:00 without any Formula 1 eh?... ops... any forumla do:
/system scheduler
disable sharing
enable night
and on ANOTHER scheduer at 05:00:00 do:
/system scheduler
disable night
enable sharing
dhiaahmed
Mon Jul 12, 2021 3:23 pm
I hope that mikrotik will add a field in the scheduler allowing scripts to be run during a specific period of time
Users browsing this forum: No registered users and 18 guests
