Cablenut9
Long time Member
Long time Member
L2TP/IPsec tunnel erases configuration
Sat Jul 10, 2021 12:29 am
I was setting up a L2TP/IPsec tunnel with a 7.1beta6 device on one end, and a 6.49beta46 on the other. After the interface was created after connecting, the v7.1 router crashed and erased the whole configuration. Luckily for me, I had made a backup the day prior just in case something like this happened. How could this have happened?
pe1chl
Re: L2TP/IPsec tunnel erases configuration
Sat Jul 10, 2021 1:29 pm
You are using beta software. It warns you to make backups, and it may be unstable.
It is known that for certain configuration changes, the v7 beta crashes and resets the configuration.
This may also happen when you upgrade to a newer v7 beta, it happened to me as well.
Luckily, you can now do a /export and save it. That did not work in an earlier beta.
Users browsing this forum: No registered users and 9 guests
