ilium007
DHCP issues 7.1beta6 ESP8266 / ESP32
Sun Jul 11, 2021 3:47 pm
I have no idea how to start debugging this one....
I have a network of ESP8266 / ESP32 devices on a Chateau LTE device. I was using this device to test with before buying ceiling mount cAP devices. I have noticed a few issues with the DHCP server that others in the ESPHome / Homeassistant (home automation) community are not experiencing.
1. DHCP client hostname does not appear in the initial DHCP assignment therefore my DHCP to DNS scripts don't work.
2. ESP devices crash / reboot when configured for DHCP (wireless) via the Mikrotik device. The devices constantly crash / reboot every 25mins.
I revived an old Billion 7800 router and configured wireless etc. Devices client name appear in DHCP list straight away and no crashes / reboots on any ESP device after 25mins. From this I can only conclude that the issue is with the Mikrotik / routerOS device rather that the ESP devices.
I have no idea how to start troubleshooting. Is it wireless / DHCP config, routerOS bug or user error with config? Cleaning up config export now and will post.
ilium007
Re: DHCP issues beta6 ESP8266 / ESP32
Sun Jul 11, 2021 3:56 pm
# jul/11/2021 07:36:37 by RouterOS 7.1beta6
# software id = 8DD5-P647
# model = RBD53G-5HacD2HnD
# serial number = C8CA0CB0B626
add admin-mac=48:8F:5A:11:24:D8 auto-mac=no comment=defconf name=bridge \
    protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n country=\
    australia disabled=no distance=indoors installation=indoor \
    keepalive-frames=disabled mode=ap-bridge multicast-buffering=disabled \
    multicast-helper=full ssid=LIBERTY station-roaming=enabled \
    wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-onlyac \
    channel-width=20/40/80mhz-Ceee country=australia disabled=no distance=\
    indoors frequency=auto installation=indoor keepalive-frames=disabled \
    mode=ap-bridge multicast-buffering=disabled multicast-helper=full ssid=\
    LIBERTY_AC station-roaming=enabled wireless-protocol=802.11 wmm-support=\
    enabled
add disabled=no mac-address=4A:8F:5A:11:24:DE master-interface=wlan1 \
    multicast-helper=full name=wlan3 ssid=ESPHOME wds-default-bridge=bridge \
    wps-mode=disabled
/interface pppoe-client
add add-default-route=yes allow=pap disabled=no interface=ether1 name=\
    pppoe-out1 password=xxxxxxxxxx use-peer-dns=yes user=\
    xxxxxxxxxx@wba.nbnonline.com.au
/interface lte
set [ find ] allow-roaming=no band="" disabled=yes name=lte1 network-mode=lte
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1 private-key=\
    "xxxxxxxxxx"
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=ltebroadband ip-type=ipv4 name=optus \
    use-network-apn=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" \
    group-key-update=1h mode=dynamic-keys supplicant-identity=MikroTik \
    wpa-pre-shared-key=xxxxxxxxxx wpa2-pre-shared-key=\
    xxxxxxxxxx
add authentication-types=wpa2-psk group-key-update=1h management-protection=\
    allowed mode=dynamic-keys name=guest supplicant-identity=MikroTik \
    wpa2-pre-shared-key=xxxxxxxxxx
/interface wireless
add disabled=no mac-address=4A:8F:5A:11:24:DD master-interface=wlan1 name=\
    wlan4 security-profile=guest ssid=LIBERTY_GUEST wds-default-bridge=bridge \
    wps-mode=disabled
add name=home-pool ranges=192.168.10.11-192.168.10.254
add address-pool=home-pool disabled=no interface=bridge lease-script=":local s\
    criptName \"dhcp2dns\"\
    \n:do {\
    \n  :log info \"DHCP CLIENT: \$\"lease-hostname\"\";\
    \n  :local scriptObj [:parse [/system script get \$scriptName source]]\
    \n  \$scriptObj leaseBound=\$leaseBound leaseServerName=\$leaseServerName \
    leaseActIP=\$leaseActIP leaseActMAC=\$leaseActMAC;\
    \n} on-error={ :log warning \"DHCP server '\$leaseServerName' lease script\
    \_error\" };" lease-time=5m name=home-dhcp
/port
set 0 name=serial0
/ppp profile
set *0 use-ipv6=no
/system logging action
set 1 disk-file-count=10 disk-file-name=disk1/log disk-lines-per-file=4096
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=wlan3
add bridge=bridge interface=wlan4
/ipv6 settings
set disable-ipv6=yes
/interface detect-internet
set detect-interface-list=all
add interface=bridge list=LAN
add interface=lte1 list=WAN
add interface=ether1 list=WAN
/interface wireguard peers
add allowed-address=10.20.0.100/32 comment=xxxxxxxxxx interface=wireguard1 \
    persistent-keepalive=25s preshared-key=\
    "xxxxxxxxxx" public-key=\
    "xxxxxxxxxx"
add allowed-address=10.20.0.101/32 comment=xxxxxxxxxx interface=wireguard1 \
    "xxxxxxxxxx"
add address=192.168.10.1/24 interface=bridge network=192.168.10.0
add address=10.20.0.1/24 interface=wireguard1 network=10.20.0.0
add address=10.0.0.2/24 interface=ether1 network=10.0.0.0
/ip dhcp-server lease
add address=192.168.10.100 client-id=1:ac:bc:32:d6:60:af mac-address=\
    AC:BC:32:D6:60:AF server=home-dhcp
add address=192.168.10.20 client-id=1:28:cf:e9:f:e0:43 mac-address=\
    28:CF:E9:0F:E0:43 server=home-dhcp
add address=192.168.10.10 mac-address=00:15:17:72:6A:C8 server=home-dhcp
add address=192.168.10.3 mac-address=DC:A6:32:51:0A:F9 server=home-dhcp
add address=192.168.10.12 client-id=\
    ff:27:20:b5:28:0:1:0:1:28:3b:c4:68:8:0:27:3b:bc:71 mac-address=\
    08:00:27:20:B5:28 server=home-dhcp
add address=192.168.10.24 mac-address=D8:F1:5B:B6:4B:D3 server=home-dhcp
add address=192.168.10.0/24 dns-server=192.168.10.1 domain=home gateway=\
    192.168.10.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip firewall address-list
add address=192.168.10.11-192.168.10.255 list=lan_clients
add address=192.168.10.100 list=support
add address=192.168.200.10 list=support
add address=192.168.200.11 list=support
add address=10.20.0.100 list=support
add address=10.20.0.101 list=support
    established,related,untracked
    invalid
add action=accept chain=input comment="wireguard accept" dst-port=13231 \
    in-interface=pppoe-out1 protocol=udp
add action=accept chain=input comment="wireguard accept http/https" dst-port=\
    80,443 in-interface=wireguard1 protocol=tcp
add action=accept chain=input comment="wireguard accept dns" dst-port=53 \
    in-interface=wireguard1 protocol=udp
add action=accept chain=input comment="wireguard accept ssh" dst-port=22 \
add action=accept chain=input comment="wireguard accept winbox" dst-port=8291 \
add action=accept chain=forward comment="wireguard accept to lan" disabled=\
    yes in-interface=wireguard1 in-interface-list=LAN
add action=accept chain=forward in-interface=wireguard1 out-interface-list=\
    WAN
add action=drop chain=input comment="drop ssh brute forcers" dst-port=22 \
    protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist \
    address-list-timeout=1w3d chain=input connection-state=new dst-port=22 \
    protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 \
    address-list-timeout=1m chain=input connection-state=new dst-port=22 \
    protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 \
    protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 \
    protocol=tcp src-address-list=!support
add action=add-src-to-address-list address-list="port scanners" \
    address-list-timeout=2w chain=input comment="Port scanners to list " \
    protocol=tcp psd=21,3s,3,1
    address-list-timeout=2w chain=input comment="NMAP FIN Stealth scan" \
    protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
    address-list-timeout=2w chain=input comment="SYN/FIN scan" protocol=tcp \
    tcp-flags=fin,syn
    address-list-timeout=2w chain=input comment="SYN/RST scan" protocol=tcp \
    tcp-flags=syn,rst
    address-list-timeout=2w chain=input comment="FIN/PSH/URG scan" protocol=\
    tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
    address-list-timeout=2w chain=input comment="ALL/ALL scan" protocol=tcp \
    tcp-flags=fin,syn,rst,psh,ack,urg
    address-list-timeout=2w chain=input comment="NMAP NULL scan" protocol=tcp \
    tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=input comment="dropping port scanners" \
    src-address-list="port scanners"
add action=accept chain=forward comment="HA SSL" disabled=yes dst-port=443 \
    in-interface=pppoe-out1 protocol=tcp
    "defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
    dst-address=127.0.0.1
    in-interface-list=!LAN log=yes log-prefix=FW-DROP
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=change-ttl chain=postrouting new-ttl=set:65 out-interface=lte1 \
    passthrough=yes
add action=dst-nat chain=dstnat comment=";;; force DNS" disabled=yes \
    dst-address=!192.168.10.2 dst-port=53 in-interface=bridge protocol=udp \
    src-address=!192.168.10.2 src-address-list=!support to-addresses=\
    192.168.10.2
add action=masquerade chain=srcnat comment=";;; force DNS" disabled=yes \
    dst-address=192.168.10.2 dst-port=53 protocol=udp src-address=\
    192.168.10.0/24 src-address-list=!support
add action=masquerade chain=srcnat disabled=yes dst-address=10.0.0.0/24 \
    out-interface=ether1
add action=dst-nat chain=dstnat dst-port=443 in-interface=pppoe-out1 \
    protocol=tcp to-addresses=192.168.10.12 to-ports=443
/ip service
set telnet disabled=yes
set ftp disabled=yes
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
add action=lookup disabled=no interface=lte1 table=main
/system clock
set time-zone-name=Australia/Sydney
/system identity
set name=router01
/system logging
set 0 disabled=yes
add action=disk topics=critical
add action=disk topics=error
add action=disk disabled=yes topics=info
add action=disk topics=warning
add action=disk disabled=yes topics=dhcp
add disabled=yes topics=dhcp
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=27.124.125.251
add address=13.55.50.68
/system package update
set channel=development
/system routerboard settings
set cpu-frequency=auto
/system routerboard mode-button
set enabled=yes on-event=dark_mode
/system scheduler
add interval=5m name=update_ddns on-event=update_ddns policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-time=startup
add interval=1d name=update_ntp on-event=update_ntp policy=\
    start-date=jan/01/1970 start-time=00:02:00
add name=router_reboot_report on-event=\
    ":delay 30\
    \n/system script run router_reboot_report" policy=\
    start-time=startup
add interval=26w3d name=update_certs on-event=update_certs policy=\
    start-date=jan/01/1970 start-time=00:00:00
add interval=1d name=email_backup on-event=email_backup policy=\
    start-date=jan/01/1970 start-time=00:03:00
add name="Lock LTE cell" on-event=":delay 30\
    \n/interface/lte/at-chat lte1 input=\"at+qnwlock=\\\"common/4g\\\",2,1725,\
    74,38770,74\"" policy=\
    start-time=startup
/system script
add dont-require-permissions=no name=dark_mode owner=*sys policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\
    \n     /system leds settings set all-leds-off=immediate \
    \n   } else={\
    \n     /system leds settings set all-leds-off=never \
    \n   }\
    \n "
add dont-require-permissions=no name=update_ntp owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
    local ntpServer \"au.pool.ntp.org\"\
    \n:local primary [resolve \$ntpServer]\
    \n:local secondary [resolve \$ntpServer]\
    \n\
    \n/system ntp client set primary-ntp \$primary\
    \n/system ntp client set secondary-ntp \$secondary\
    \n\
    \n:local ntpenabled [/system ntp client get enabled]\
    \n\
    \n/system ntp client\
    \n:if (!\$ntpenabled) do={\
    \n    set enabled=\"yes\"\
    \n}"
add dont-require-permissions=no name=router_reboot_report owner=admin policy=\
    delay 1\
    \n\
    \n:local reportBody \"\"\
    \n\
    \n:local deviceName [/system identity get name]\
    \n:local deviceDate [/system clock get date]\
    \n:local deviceTime [/system clock get time]\
    \n:local hwModel [/system routerboard get model]\
    \n:local currentFirmware [/system routerboard get current-firmware]\
    \n:local upgradeFirmware [/system routerboard get upgrade-firmware]\
    \n\
    \n:set reportBody (\$reportBody . \"Router Reboot Report for \$deviceName\
    \\n\")\
    \n:set reportBody (\$reportBody . \"Report generated on \$deviceDate at \$\
    deviceTime\\n\\n\")\
    \n:set reportBody (\$reportBody . \"Hardware Model: \$hwModel\\n\")\
    \n:set reportBody (\$reportBody . \"Current Firmware: \$currentFirmware\\n\
    \n:set reportBody (\$reportBody . \"Upgrade Firmware: \$upgradeFirmware\")\
    \n\
    \n:set reportBody (\$reportBody . \"\\n\\n=== Critical Log Events ===\\n\\\
    n\" )\
    \n\
    \n:local x\
    \n:local ts\
    \n:local msg\
    \nforeach i in=([/log find where topics~\"critical\"]) do={\
    \n:set \$ts [/log get \$i time]\
    \n:set \$msg [/log get \$i message]\
    \n:set \$reportBody (\$reportBody  . \$ts . \" \" . \$msg . \"\\n\" )\
    \n}\
    \n\
    \n:set reportBody (\$reportBody . \"\\n=== End of report ===\\n\")\
    \n\
    \n/tool e-mail send subject=\"[\$deviceName] Router Reboot Report\" to=\"xxxxxxxxxx@gmail.com\" body=\$reportBody\
    \n"
add dont-require-permissions=no name=update_certs owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="{\
    \n  :do {\
    \n      /tool fetch url=https://mkcert.org/generate/ check-certificate=yes\
    \_dst-path=cacert.pem;\
    \n      /certificate remove [ find where authority expired ];\
    \n      /certificate import file-name=cacert.pem passphrase=\"\";\
    \n      /file remove cacert.pem;\
    \n  } on-error={\
    \n      :log error (\"Failed to update certificate trust store\");\
    \n  };\
    \n}"
add dont-require-permissions=no name=email_backup owner=admin policy=\
    local emailSubject\
    \n:local emailBody\
    \n\
    \n:set emailSubject (\"Mikrotik Backup - \" . \$deviceName)\
    \n:set emailBody (\$emailBody . \"Model: \" . \$hwModel . \"\\n\")\
    \n:set emailBody (\$emailBody . \"Current Firmware: \" . \$currentFirmware\
    \_. \"\\n\")\
    \n\
    \n\
    \n/system backup save name=router01 dont-encrypt=yes password=xxxxxxxxxx\
    \n\
    \n/tool e-mail send to=\"xxxxxxxxxx@gmail.com\" subject=\$emailSubject bo\
    dy=\$emailBody file=\"router01.backup\"\
    \n\
    \n:log info \"Backup e-mail sent\""
add dont-require-permissions=no name=reboot owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
    /system/reboot
add dont-require-permissions=no name=dhcp2dns owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="#\
    \_DNS TTL to set for DNS entries\
    \n:local dnsttl \"00:15:00\";\
    \n\
    \n###\
    \n# Script entry point\
    \n#\
    \n# Expected environment variables:\
    \n# leaseBound         1 = lease bound, 0 = lease removed\
    \n# leaseServerName    Name of DHCP server\
    \n# leaseActIP         IP address of DHCP client\
    \n# leaseActMAC        MAC address of DHCP client\
    \n# leaseHostname      Client hostname\
    \n###\
    \n\
    \n# \"a.b.c.d\" -> \"a-b-c-d\" for IP addresses used as replacement for mi\
    ssing host names\
    \n:local ip2Host do=\\\
    \n{\
    \n  :local outStr\
    \n  :for i from=0 to=([:len \$inStr] - 1) do=\\\
    \n  {\
    \n    :local tmp [:pick \$inStr \$i];\
    \n    :if (\$tmp =\".\") do=\\\
    \n    {\
    \n      :set tmp \"-\"\
    \n    }\
    \n    :set outStr (\$outStr . \$tmp)\
    \n  }\
    \n  :return \$outStr\
    \n}\
    \n\
    \n:local mapHostName do={\
    \n# param: name\
    \n# max length = 63\
    \n# allowed chars a-z,0-9,-,_\
    \n  :local allowedChars \"abcdefghijklmnopqrstuvwxyz0123456789-_\";\
    \n  :local numChars [:len \$name];\
    \n  :if (\$numChars > 63) do={:set numChars 63};\
    \n  :local result \"\";\
    \n\
    \n  :for i from=0 to=(\$numChars - 1) do={\
    \n    :local char [:pick \$name \$i];\
    \n    :if ([:find \$allowedChars \$char] < 0) do={:set char \"-\"};\
    \n    :set result (\$result . \$char);\
    \n  }\
    \n  :return \$result;\
    \n}\
    \n\
    \n:local lowerCase do={\
    \n# param: entry\
    \n  :local lower \"abcdefghijklmnopqrstuvwxyz\";\
    \n  :local upper \"ABCDEFGHIJKLMNOPQRSTUVWXYZ\";\
    \n  :for i from=0 to=([:len \$entry] - 1) do={\
    \n    :local char [:pick \$entry \$i];\
    \n    :local pos [:find \$upper \$char];\
    \n    :if (\$pos > -1) do={:set char [:pick \$lower \$pos]};\
    \n  }\
    \n}\
    \n\
    \n:local token \"\$leaseServerName-\$leaseActMAC\";\
    \n:local LogPrefix \"DHCP2DNS (\$leaseServerName)\"\
    \n\
    \n:if ( [ :len \$leaseActIP ] <= 0 ) do=\\\
    \n{\
    \n  :log error \"\$LogPrefix: empty lease address\"\
    \n  :error \"empty lease address\"\
    \n}\
    \n\
    \n:if ( \$leaseBound = 1 ) do=\\\
    \n{\
    \n  # new DHCP lease added\
    \n  /ip dhcp-server\
    \n  #:local dnsttl [ get [ find name=\$leaseServerName ] lease-time ]\
    \n  network\
    \n  :local domain [ get [ find \$leaseActIP in address ] domain ]\
    \n  #:log info \"\$LogPrefix: DNS domain is \$domain\"\
    \n\
    \n  :local hostname [/ip dhcp-server lease get value-name=host-name [find \
    mac-address=\$leaseActMAC and server=\$leaseServerName]]\
    \n  #:local hostname=\$leaseHostname\
    \n  #:log info \"\$LogPrefix: DHCP hostname is \$hostname\";\
    \n\
    \n #Hostname cleanup\
    \n  :if ( [ :len \$hostname ] <= 0 ) do=\\\
    \n  {\
    \n    :set hostname [ \$ip2Host inStr=\$leaseActIP ]\
    \n    :log info \"\$LogPrefix: Empty hostname for '\$leaseActIP', using ge\
    nerated host name '\$hostname'\"\
    \n  }\
    \n  :set hostname [\$lowerCase entry=\$hostname]\
    \n  :set hostname [\$mapHostName name=\$hostname]\
    \n  #:log info \"\$LogPrefix: Clean hostname for FQDN is \$hostname\";\
    \n\
    \n  :if ( [ :len \$domain ] <= 0 ) do=\\\
    \n  {\
    \n    :log warning \"\$LogPrefix: Empty domainname for '\$leaseActIP', can\
    not create static DNS name\"\
    \n    :error \"Empty domainname for '\$leaseActIP'\"\
    \n  }\
    \n\
    \n  :local fqdn (\$hostname . \".\" .  \$domain)\
    \n  #:log info \"\$LogPrefix: FQDN for DNS is \$fqdn\"\
    \n\
    \n    :if ([/ip dhcp-server lease get [find mac-address=\$leaseActMAC and \
    server=\$leaseServerName]]) do={\
    \n      # :log info message=\"\$LogPrefix: \$leaseActMAC -> \$hostname\"\
    \n      :do {\
    \n        /ip dns static add address=\$leaseActIP name=\$fqdn ttl=\$dnsttl\
    \_comment=\$token;\
    \n      } on-error={:log error message=\"\$LogPrefix: Failure during dns r\
    egistration of \$fqdn with \$leaseActIP\"}\
    \n    }\
    \n\
    \n} else={\
    \n# DHCP lease removed\
    \n  /ip dns static remove [find comment=\$token];\
    \n}"
/system watchdog
set watchdog-timer=no
/tool e-mail
set address=smtp.gmail.com from=router@homenet password=xxxxxxxxxx \
    port=587 tls=starttls user=xxxxxxxxxx@gmail.com
/tool mac-server
/tool mac-server mac-winbox
/tool sms
set allowed-number=+xxxxxxxxxx auto-erase=yes port=lte1 receive-enabled=yes \
    secret=12345
/tool sniffer
set filter-interface=wireguard1 memory-limit=1024KiB streaming-enabled=yes \
    streaming-server=192.168.10.100
ilium007
Sun Jul 11, 2021 4:01 pm
The is the uptime graph from the other day:
The last set on this uptime graph is after changing from the Miktrotik Chateau router to the Billion router:
sid5632
Long time Member
Long time Member
Sun Jul 11, 2021 4:14 pm
I can conclude that the issue is with the Mikrotik / routerOS device rather that the ESP devices.
A very strange conclusion.
Maybe you would do better to look at the ridiculously short lease-time setting that you have (5 minutes) and compare what it is on the Billion (probably 24h) and then take the appropriate action.
Either way, the real problem is with your ESP devices' software which seem to have a problem with short lease time.
ilium007
Mon Jul 12, 2021 11:50 am
The 'ridiculously short lease-time' was set in order to get hostnames to appear in the DHCP lease table. Once a device renews its lease the name appears in the table but not on first issue. If I left it at 10hrs I would be waiting 5hrs for the renewal to trigger the name to appear in the lease table.
The 5min lease time in no way corresponds to the 25min reboot frequency observed.
Device is still up, connected to the Billion.
If its not a Mikrotik problem then why did everything work perfectly with the Billion device?
ilium007
Mon Jul 12, 2021 11:57 am
Should I put the Mikrotik Chateau LTE back in play, increase lease time to 10hrs and post back with the same 25min reboot schedule that led me to reduce lease time to 5min? I was hoping someone might take a look at the wireless config and see if there is anything in there that may be causing issue.
ilium007
Mon Jul 12, 2021 12:47 pm
Reinstated the Mikrotik Chateau LTE and set DHCP lease time to 10hr. Straight away I can see that the ESP devices have no host name in the DHCP table (red box):
I have now waited 50mins and right on queue the device reboots at 25mins intervals:
I don't think this is related to DHCP lease time (5min vs 10hr). If its a configuration issue I need to look at advanced wireless interface settings but no idea where to start.
ilium007
Tue Jul 13, 2021 2:32 pm
So this ESP8266 is running ESPHome, a home automation firmware that integrates with HomeAssistant. I performed an erase and uploaded Tasmota (a competing home automation firmware) and on the Mikrotik Chateau LTE it again fails to register in the DHCP table with a hostname.
Packet trace shows that the DHCP request packet does include the hostname that is NOT appearing in the DHCP table in the Mikrotik router. Not sure what else I can provide to troubleshoot.
dhcp_office-test-0.pcap.zip
ilium007
Tue Jul 13, 2021 3:02 pm
Changed device name to remove hyphens in case that was causing issues but same story, host name does not appear in DHCP table.
ilium007
Re: DHCP issues 7.1beta6 ESP8266 / ESP32
Wed Jul 14, 2021 1:59 am
So… recapping.
When I have these ESP devices configured with DHCP and connected to the Mikrotik router they do not register their hostnames in the DHCP table until their first renewal even though they send DHCP option 12 in their DHCP request packet. There is a second issue whereby when configured with DHCP connected to the Mikrotik router they reboot after 1500s / 25min consistently.
Neither of these issues occur when connected with DHCP to a cheap Billion 7800 VDOX router. The Mikrotik router is turned off and the Billion turned on with the same wireless SSID.
ilium007
Tue Jul 20, 2021 12:54 pm
I purchased more Mikrotik hardware to run routerOS 6.48.3 and again, exactly the same issue.
vinigas
Thu Jul 29, 2021 10:56 pm
Add firewall passthrough rules with logging. It may help to detect what is going on.
Also it is possible to setup WireShark to see what going through Mikrotik and your ESP32.
ilium007
Fri Jul 30, 2021 12:52 am
I already have wireshark captures and think I know what’s happening. The ESP8266 is not sending an ‘option 12 hostname’ field in the DHCP DISCOVER packet. It only sends the hostname in the DHCP REQUEST packet. It seems some routers will accept the hostname if it’s present in only the REQUEST packet, my Ubiquiti EdgeRouter doesn’t care, but RouterOS wants the hostname in both the DISCOVER and REQUEST packets. If routerOS only gets the hostname in the REQUEST packet it ignores it.
RFC3397 - https://tools.ietf.org/search/rfc3397- doesn’t mandate which behavior is correct.
Zary
Thu Aug 19, 2021 9:57 pm
I ran into this problem a few months ago, and at the time I thought it was my AP's fault
Victor4X
Mon Aug 30, 2021 10:46 am
Would it be possible to change this with a script on the router?
Either change the behaviour to only require a hostname in the request packet, or change the discover packet to include the hostname before it is evaluated?
cristianm
Sat Sep 11, 2021 4:34 pm
Same issue here with HomeAssistant and ESPHome and another devices that uses ESP hardware. Unstable wifi, only with ESP devices and mikrotik.
ilium007
Fri Sep 17, 2021 2:09 am
I gave up on trying to get it working and now just run dnsmasq in a docker container for both dhcp and dns. Works perfectly.
Users browsing this forum: No registered users and 38 guests
