MUM Europe 2020
elkolo23
MSN MESSENGER NOT CONNECTING
Fri Aug 10, 2007 6:37 am
currently i have aproblem which happends to my isp customers,,...-
msn messenger is not connecting,, unablke to log in from all my customers computers..
yahoo messenger,skype and all other meesenger applications..
i had noticed days ago that if i limited client connections msn woudnt work..
i did disable that rule now but msn still not works..
just msn messenger since i can check emails from hotmail.com i know the problem is only with msn messenger.
p`lease help me with this..
best regards
raktim
Re: MSN MESSENGER NOT CONNECTING
Fri Aug 10, 2007 4:33 pm
i think u have to check the firewall settings may be u have dropped some ports...
MarTux
Fri Aug 10, 2007 5:00 pm
You must check your firewall configuration. All the ports used by msn must be opened.
This is the list of the ports used by msn:
-80 (tcp) : Conversation, games
-1863 (tcp): Conversation
- 6891-6900 (tcp): files transfers
- 6901 (tcp and udp) voice conversation
- 443 (tcp): login, password, secure connexions
- 9000-9999 (random ports) (tcp): WebCam
- 3389 (tcp): remote assistance.
- 1503 (cp) : white bord, shared applications
Good Chat
elkolo23
Fri Aug 10, 2007 10:55 pm
all those ports are open,, it happends that in some computers msn is working and in others not... i did reinstall msn on the ones not working but is the same ...
could it be the ethernet adapter of the ones not working the problem??? coulkd it be possible even though the pc is surfing?
brundier
Sat Aug 11, 2007 4:24 am
Did u disable masquerade or src-nat?
If u disable masquerade or src-nat any massanger wont work :)
elkolo23
Tue Aug 14, 2007 6:47 am
both are working(enabled)
mabsolutions
Thu Aug 16, 2007 12:01 am
If you are making connection to your ISP with PPPoe check that your MTU setting is at 1492, that solved the problem for me
elkolo23
Thu Aug 16, 2007 7:15 am
it using static ips,no ppoe..
what ive found out something is eating up my upload speed..
i have 3meg down and up but ive noticed it will only displays as 250 o300kbps of upload while 3000kbps download.
sergejs
Thu Aug 16, 2007 8:45 am
You may use torch to track down the addresses and traffic that uses your upload, make sure that these ports are opened and you are using 2.9.46 version.
music
Mon Aug 20, 2007 7:45 pm
reboot your router
Users browsing this forum: No registered users and 19 guests
