markwien
/tool fetch url doest work
Wed Jul 28, 2021 1:34 pm
Hi i try to fetch all files in /file and copy them to a other mikrotik.
When i use the tool in command line it works fine, but inside the script it doesnt. Can someone tell me how to write it correct?
/tool fetch url=sftp://XXXXXX/test.txt upload=yes user=backupuser password=XXXXXXsrc-path=test.txt src-address=XXXXX
:foreach a in=[/file find] do={
    /tool fetch url=("sftp://XXXXXXX/" .$a) upload=yes user=backupuser password=ashahahha src-path=$a src-address=92.XXXXXXX;
thx
mark
rextended
Re: /tool fetch url doest work
Wed Jul 28, 2021 1:55 pm
You forget to not send.... directories and disks...
Your remote sftp create directories when are not presents?
:local filelist ""
/file
:foreach file in=[find where type!=disk and type!=directory] do={
    /tool fetch url=("sftp://XXXXXXX/$file") upload=yes user=backupuser password=ashahahha src-path=$file src-address=92.x.x.x
For true backup you can adapt this, is by mail, but you can modify it to use fetch:
viewtopic.php?f=1&t=175360&p=858564#p858564
Users browsing this forum: No registered users and 39 guests
