N0sey
Wireless dropping to 2 of many devices
Tue Aug 10, 2021 10:15 pm
HI all, I'm new to Mikrotik and I have a problem with two of the wireless devices attached to the wireless router.
Both connect and disconnect regularly. One is a Dell laptop, the other an iPhone.
Looking at the logs suggests to me that the devices, rather than the router, are the problem, disconnecting themselves. But I would like to check.
It seems very odd that this should happen to two devices, not one, or all.
Here's a relevant extract:
		958	Aug/10/2021 12:03:24	memory	dhcp, info	defconf deassigned 172.16.1.101 from 7C:50:79:AC:49:23
		959	Aug/10/2021 12:03:44	memory	dhcp, info	defconf deassigned 172.16.1.102 from 2A:E8:88:98:E6:C2
		960	Aug/10/2021 15:55:48	memory	wireless, info	2A:E8:88:98:E6:C2@wlan2: connected, signal strength -73
		961	Aug/10/2021 15:55:53	memory	dhcp, info	defconf assigned 172.16.1.102 to 2A:E8:88:98:E6:C2
		962	Aug/10/2021 15:56:31	memory	wireless, info	7C:50:79:AC:49:23@wlan2: connected, signal strength -77
		963	Aug/10/2021 15:56:32	memory	dhcp, info	defconf assigned 172.16.1.101 to 7C:50:79:AC:49:23
		964	Aug/10/2021 15:59:28	memory	wireless, info	7C:50:79:AC:49:23@wlan2: disconnected, received deauth: unspecified (1)
		965	Aug/10/2021 16:06:32	memory	dhcp, info	defconf deassigned 172.16.1.101 from 7C:50:79:AC:49:23
		966	Aug/10/2021 16:12:44	memory	wireless, info	7C:50:79:AC:49:23@wlan2: connected, signal strength -74
		967	Aug/10/2021 16:12:56	memory	dhcp, info	defconf assigned 172.16.1.101 to 7C:50:79:AC:49:23
		968	Aug/10/2021 16:13:00	memory	wireless, info	7C:50:79:AC:49:23@wlan2: disconnected, received deauth: unspecified (1)
		969	Aug/10/2021 16:13:02	memory	wireless, info	7C:50:79:AC:49:23@wlan2: connected, signal strength -76
		970	Aug/10/2021 16:13:16	memory	wireless, info	7C:50:79:AC:49:23@wlan2: disconnected, received deauth: unspecified (1)
		971	Aug/10/2021 16:13:22	memory	wireless, info	7C:50:79:AC:49:23@wlan2: connected, signal strength -74
		972	Aug/10/2021 16:15:55	memory	wireless, info	7C:50:79:AC:49:23@wlan2: disconnected, received deauth: unspecified (1)
		973	Aug/10/2021 16:17:43	memory	wireless, info	7C:50:79:AC:49:23@wlan2: connected, signal strength -79
		974	Aug/10/2021 16:17:54	memory	wireless, info	7C:50:79:AC:49:23@wlan2: disconnected, received deauth: unspecified (1)
		975	Aug/10/2021 16:23:22	memory	dhcp, info	defconf deassigned 172.16.1.101 from 7C:50:79:AC:49:23
		976	Aug/10/2021 16:55:42	memory	wireless, info	2A:E8:88:98:E6:C2@wlan2: disconnected, received disassoc: sending station leaving (8)
		977	Aug/10/2021 16:57:32	memory	wireless, info	2A:E8:88:98:E6:C2@wlan2: connected, signal strength -72
		978	Aug/10/2021 17:02:47	memory	wireless, info	2A:E8:88:98:E6:C2@wlan2: disconnected, extensive data loss
		979	Aug/10/2021 17:07:35	memory	dhcp, info	defconf deassigned 172.16.1.102 from 2A:E8:88:98:E6:C2
		980	Aug/10/2021 17:19:43	memory	wireless, info	7C:50:79:AC:49:23@wlan2: connected, signal strength -79
		981	Aug/10/2021 17:19:48	memory	dhcp, info	defconf assigned 172.16.1.101 to 7C:50:79:AC:49:23
		982	Aug/10/2021 17:19:53	memory	wireless, info	7C:50:79:AC:49:23@wlan2: disconnected, received deauth: unspecified (1)
		983	Aug/10/2021 17:29:48	memory	dhcp, info	defconf deassigned 172.16.1.101 from 7C:50:79:AC:49:23
At times, the signal strength looks low, but the disconnects seem to happen when it's better as well.
Thanks for any observations,
N0sey
ConnyMercier
Forum Veteran
Forum Veteran
Re: Wireless dropping to 2 of many devices
Thu Aug 12, 2021 11:56 am
Good Morning N0sey,
Do you get does events while USING your Iphone or Laptop ?
Or are does event happening , wenn you are not using them ?
N0sey
Tue Aug 17, 2021 9:30 pm
Sorry for the delay, my daughter uses the devices and she's now away.
But I believe the problems occurred while using them.
EDIT - In addition, the problems occurred in various parts of the house where other devices have no problem. I suppose it's still possible that both have poor antennas and voluntarily disco because of that. But the log I posted shows them discoing with reasonable signal.
N0sey
bpwl
Tue Aug 17, 2021 11:50 pm
Difficult to find why client disconnects. I see quite often a DHCP deassign of the IP address. No IP address is one of the possible reasons why a client is dropping the connection.
By the log also says "deauth", so check the security profile (if you have multiple AP's with the same SSID, the security profiles must fully match (WPA/WPA2, TKIP/AES)
viewtopic.php?f=7&t=136334#p840725
Users browsing this forum: No registered users and 37 guests
