informaticaconancun2
Routerboard 1100 AHx2 Ports 1-10 not working
Fri Aug 13, 2021 9:20 pm
hello i been working with a Routerboard 1100AHx2 as my primary router for my school network, 2 days ago sudenly the router stoped "working" the ports 1-5 have all the leds on and the 6-10 dont but neither 1-10 ports gives signal, i tried using the port 12 (bypass) to connect via winbox and its working but with the other ports i cant connect, i did a reset via winbox and a hard reset(physically) and still cant fix the 1-10 ports, my question, is there any way to fix this?
Zacharias
Re: Routerboard 1100 AHx2 Ports 1-10 not working
Mon Aug 16, 2021 8:00 pm
Are the Leds On even if there is no cable connected ?
you could try to netinstall your device ...
https://wiki.mikrotik.com/wiki/Manual:Netinstall
Thu Aug 19, 2021 9:51 pm
port 1-5 have the leds "on" 6-10 dont, already did a netinstall only port 12 is working for access via winbox, port 13 did work for the netinstall
Zacharias
Fri Aug 20, 2021 9:32 am
If the Leds are on, even with no cable connected and you did netinstall the device, if the problem is not solved then it seems as a hardware problem...
Users browsing this forum: No registered users and 29 guests
