jvgenderen
capsman dualband with same SSID on different channels ?
Wed Aug 18, 2021 7:04 pm
Hi.
i am having an issue with my capsman config.
i am running one ssid on both 2.4 and 5ghz.
i have on 2,4 ghz in the caps config tab the freq 2412 and 2462 and this works. but on 5ghz not. when i put different freq in.
google does provide me with a helpful answer.
any helpful hints :-)
/Joost
Zacharias
Re: capsman dualband with same SSID on different channels ?
Thu Aug 19, 2021 1:02 am
What exactly does not work?
Give more details ...
erlinden
Thu Aug 19, 2021 8:53 am
Per radio you can have a single frequency (or a list of frequencies that the device chooses from). It is not possible to use multiple frequencies on a single radio.
Zacharias
Fri Aug 20, 2021 9:29 am
A single radio can't use more than one frequencies anyways... (except on 5GHz, when using the secondary frequency feature for 160MHz channels)
The AP will only choose 1 frequency to use...
So even if you put multiple frequencies in the List, only 1 will be chosen...
normis
Fri Aug 20, 2021 9:56 am
What model of WiFI devices are you controlling?
Show us the CAPsMAN config please.
jvgenderen
Sun Aug 22, 2021 4:00 pm
hi guys.
apperently i did not recieved a email when you guys replied.
problem solved ;-)
it's working perfectly.
i will use provision on the mac adres => every AP has it own config with the channels config in it.
Thanks.
Zacharias
Sun Aug 22, 2021 5:25 pm
What exactly did you solve?
As stated in my earlier post, even if you put 2 or 3 frequencies in the List, only 1 will be used...
Even if you configure different frequencies, on slave configuration for example, only the frequency in the master configuration will be used...
You can check that with a wifi analyzer....
jvgenderen
Thu Aug 26, 2021 5:39 pm
i made different configs for every AP radio with different channels.
i have 2 dual band ap units. => 4 configs.
provision rule for every radio macadres
i checked it with a wifi analyser and this works.
i hope this makes any sense to you . ;)
Joost.
Zacharias
Fri Aug 27, 2021 3:51 pm
Sorry but you can't use different frequencies on the same radio Band...
Can you show the details from the Network analyzer ? As you re saying, you are using two frequencies for the 2.4 GHz at the same time, lets say 2412 and 2437 and two frequencies at the same time ( without the use of secondary frequency ) for the 5 GHz Band, lets say 5180 and 5200 or anything...
Wiki:
Virtual interfaces will always use the Master interface wireless frequency
Source: https://wiki.mikrotik.com/wiki/Manual:I ... interfaces
Also from WiKi:
There are settings that are meaningful only for master interface, i.e. mainly hardware setup related settings such as radio channel settings
Source: https://wiki.mikrotik.com/wiki/Manual:CAPsMAN
jvgenderen
Fri Aug 27, 2021 5:21 pm
yes. i have 2 ap's
one ssid in the network.
ap 1 => 2412 and 5180
ap 2 => 2462 and 5875
i do NOT use 2 freq on one the same band at the same time .
Joost.
Brain2000
Thu Oct 31, 2024 11:11 pm
Is it possible to set up the secondary frequency for a 160mhz channel on the wifi1 interface, then create two virtual SSID's that each use one of the 80mhz channels?
I'm thinking probably not, but I have to ask...
mkx
Fri Nov 01, 2024 10:23 am
No, it's single radio regardless the channel width. Virtual SSIDs operate over "master" channel, they can't have separate radio settings.
