stefki
PPPoE Server over BGP VPLS signaling
Wed Aug 25, 2021 12:59 pm
Hello all. Last few days I am trying to setup simple PPPoE server over BGP VPLS tunnel .
VPLS got connected at the end of my client devices, but unfortunately the PPPoE connection won't get trough over vpls.
I really appreciate it if someone of you could help me . Thank you
This is my lab diagram
R1 config
add name=Loopback
add name=vpls-bridge protocol-mode=none
/routing bgp instance
set default as=100 router-id=1.255.255.1
/interface pppoe-server server
add authentication=pap,chap disabled=no interface=vpls-bridge service-name=service1
/interface vpls bgp-vpls
add bridge=vpls-bridge export-route-targets=1:3 import-route-targets=1:3 name=R3 route-distinguisher=1:3
add address=10.0.0.1/24 interface=ether2 network=10.0.0.0
add address=1.255.255.1 interface=Loopback network=1.255.255.1
/ip dhcp-client
add disabled=no interface=ether1
/ppp secret
add name=test password=test service=pppoe
/routing bgp network
add network=10.0.0.0/24 synchronize=no
add network=9.0.0.0/24 synchronize=no
add network=1.255.255.0/24 synchronize=no
/routing bgp peer
add address-families=ip,l2vpn name=R2 remote-address=10.0.0.2 remote-as=102
/system identity
set name=R1
/tool romon
set enabled=yes
R2 Config
add name=Loopback
set default as=102 router-id=1.255.255.2
add address=1.255.255.2 interface=Loopback network=1.255.255.2
add address=10.0.0.2/24 interface=ether1 network=10.0.0.0
add address=9.0.0.1/24 interface=ether2 network=9.0.0.0
/routing bgp peer
add address-families=ip,l2vpn name=R1 remote-address=10.0.0.1 remote-as=100
add address-families=ip,l2vpn name=R3 remote-address=9.0.0.2 remote-as=65550
/system identity
set name=R2
/tool romon
set enabled=yes
R3 Config
add name=Loopback
add name=bridge1 protocol-mode=none
/interface pppoe-client
add add-default-route=yes disabled=no interface=bridge1 name=pppoe-out1 password=test user=test
set default as=65550 router-id=10.255.255.3
add bridge=bridge1 export-route-targets=1:3 import-route-targets=1:3 name=R1 route-distinguisher=1:3 site-id=3
add address=9.0.0.2/24 interface=ether1 network=9.0.0.0
add address=10.255.255.3 interface=Loopback network=10.255.255.3
/routing bgp peer
add address-families=ip,l2vpn name=R2 remote-address=9.0.0.1 remote-as=102
/system identity
set name=R3
/tool romon
set enabled=yes
R1 VPLS status
admin@R1] > /interface vpls print detail
Flags: X - disabled, R - running, D - dynamic, B - bgp-signaled, C - cisco-bgp-signaled
 0 RDB name="vpls5" mtu=1500 l2mtu=1500 mac-address=02:33:9F:06:85:3C arp=enabled arp-timeout=auto disable-running-check=no remote-peer=10.0.0.2 cisco-style=no cisco-style-id=0 advertised-l2mtu=1500 pw-type=raw-ethernet use-control-word=yes vpls=R3
R3 VPLS connected
[admin@R3] > /interface vpls print detail
 0 RDB name="vpls7" mtu=1500 l2mtu=1500 mac-address=02:5B:71:5F:8D:4E arp=enabled arp-timeout=auto disable-running-check=no remote-peer=9.0.0.1 cisco-style=no cisco-style-id=0 advertised-l2mtu=1500 pw-type=raw-ethernet use-control-word=yes vpls=R1
nichky
Re: PPPoE Server over BGP VPLS signaling
Thu Aug 26, 2021 7:55 am
what have you bridget in to vpls-bridge.
Can't see that you put anything in there
stefki
Thu Aug 26, 2021 10:21 am
Yes I don't have nothing in vpls-bridge.
OK now I put ether2 in vpls-bridge on R1
and on R3 I put ether1
But still nothing pppoe won't connect.
nichky
Thu Aug 26, 2021 12:20 pm
of course, vpls is down
stefki
Thu Aug 26, 2021 3:19 pm
Let's try new VPLS tunnel configured on R2. Boom the VPLS got connected and PPPoE connection too. So there is must be something wrong with R2 because the VPLS don't go trough it to R3.
nichky
Fri Aug 27, 2021 12:51 am
from R2 where pppoe terminate, can you ping the remote ip -address.
Then do traceroute to google and see where is stopping
For me it seems like thet layer 2 is fine, you need to check something on R1 where you internet is.
Users browsing this forum: saahil and 67 guests
