MoviNET08
LTE interface does not appear (R11e-LTE-US)
Wed Aug 25, 2021 3:51 pm
I have the LtAP mini to which I put the LTE R11e-LTE-US card. I loaded the latest long-term software 6.47.10 and the LTE interface does not appear. When I look at the USB resources, the R11e-LTE-US shows up as Google and the Android device provider followed by the serial number. Does anyone have an idea how to correct this or why it is happening?
SiB
Re: LTE interface does not appear (R11e-LTE-US)
Tue Sep 07, 2021 11:25 am
RouterOs 6 or 7 ?
Try do System > Reset Configuration > Reset Configuration button
And at standard configuration it's should be work. You should provice some export file form unit to analyze it.
Lynx56
Tue Sep 19, 2023 4:25 pm
The power supply adaptor is the problem! If using OEM supplied my Mikrotik (12V 0.8A), it doesn't work :-?
12V 2A works like charm
Users browsing this forum: Ahrefs [Bot], GoogleOther [Bot], grusu, sinisa and 35 guests
