Dani1250
Passive parameter in IPsec->Peer
Fri Aug 27, 2021 4:23 pm
Good afternoon,
I'm using Mikrotik's chr-6.48.3 version to make a script that creates a site-to-site IPsec tunnel. Whenever I run the command "ip ipsec peer add passive=no" via script or console the parameter "passive" is set to "yes" instead of "no".
Has anyone had this problem? Is there any solution to solve the problem?
Any help, I appreciate it.
Compliments,
Daniel Rodrigues
pe1chl
Re: Passive parameter in IPsec->Peer
Fri Aug 27, 2021 4:35 pm
passive=no is the default, no need to pass that in your command!
Dani1250
Mon Aug 30, 2021 7:22 pm
Good afternoon pe1chl,
I've tried it without passing the "passive" argument in the command and the behavior is the same.
Dani1250
Re: Passive parameter in IPsec->Peer  [SOLVED]
Wed Sep 29, 2021 3:27 pm
Good afternoon,
Problem solved. It is necessary in the script to specify the peer address.
Users browsing this forum: No registered users and 79 guests
