ashrfo
login failure for user
Mon Aug 30, 2021 11:15 am
login failure for user admin from 14.1.1.2 via api
Hello my friends
I upgraded the router to the latest version 6.48 and then it gives a failure to log in from the mikro winbox mobile app
Before the update everything was fine
I checked the api settings and there is nothing
can you help
pe1chl
Re: login failure for user
Mon Aug 30, 2021 11:34 am
What was your previous version?
When it was very old, you will need to update your api program because the authentication in the api has changed.
Users browsing this forum: No registered users and 39 guests
