dhiaahmed
l2tp client problem
Mon Aug 30, 2021 4:36 pm
I have configured L2tp client on mikrotik 951 to open some blocked apps. I've done the mangle routing mark for the network ,NAT and the default route to go through the l2tp connection.
the problem is the L2tp interface RX is always 0 as shown in the attached pic. I don't know what's the problem !
NOTE: when I try the L2tp account on another 951 routerboard it works fine
mrz
Re: l2tp client problem  [SOLVED]
Mon Aug 30, 2021 4:45 pm
Make sure you have a route to the l2tp server, otherwise you are making forwarding loop over the default route.
dhiaahmed
Mon Aug 30, 2021 5:01 pm
Is this correct !
mrz
Mon Aug 30, 2021 5:50 pm
Your screenshots do not show any routes to the L2TP server.
dhiaahmed
Mon Aug 30, 2021 6:10 pm
Umm,I think all the traffic with the local mark routing will go to the internet through the l2tp
dhiaahmed
Tue Aug 31, 2021 6:29 pm
still have no solution.
Users browsing this forum: No registered users and 16 guests
