Dreaken
MikroTik RBLHGR&R11e-4G
Thu Sep 02, 2021 12:48 am
Hi, I have a MikroTik RBLHGR&R11e-4G (LHG 4G kit) Outdoor Directional WiFi 4 4G/LTE Cat 4 Router Kit
In RouterOS under wireless I expected to see a wireless card as I understood this model had one installed.
I successfully have 4G internet connectivity which I now want to share with the wifi card but I can't seem to find the wireless card on Router OS, the wifi interface table is blank
Any help appreciated.
ConnyMercier
Forum Veteran
Forum Veteran
Re: MikroTik RBLHGR&R11e-4G
Thu Sep 02, 2021 5:19 pm
The Mikrotik RBLHGR&R11e-4G only as LTE and 1 Ethernet-Port
you can look it up on the Mirkotik-Website : https://mikrotik.com/product/lhg_4g_kit#fndtn-downloads
normis
Thu Sep 02, 2021 5:41 pm
Yes, the model has no wifi mentioned anywhere. Your name for this kit is wrong "MikroTik RBLHGR&R11e-4G (LHG 4G kit) Outdoor Directional WiFi 4 4G/LTE Cat 4 Router Kit" there is no such product by MikroTik.
The RBLHGR&R11e-4G has one LTE for uplink, and one Ethernet for the LAN, where you would normally connect a MikroTik WiFi indoor router.
Dreaken
Fri Sep 03, 2021 1:14 am
Thank you both, you’ve saved me a lot of time! Looks like the distributor has an incorrect description. https://www.broadbandbuyer.com/product ... d-r11e-4g/
I thought it might be too good to be true. On the positive I’ve learnt a lot about RouterOS trying to get something to work!
Very pleased with the the device, I just need to find a really low power access point to complement it now.
Thank you.
ConnyMercier
Forum Veteran
Forum Veteran
Fri Sep 03, 2021 1:29 am
Mikrotik have a nice assortment of little WLAN-AccesPoint
https://mikrotik.com/products/group/wir ... and-office
If you only need a small 2.4 Ghz Network, the cheapest 20$ Router will probably do the Trick!
Tipp:
The mAP lite ist a FUN little 2.4GHz Router to have.
For >= 25$ you can always re-use it as a Travel-Router.
Users browsing this forum: No registered users and 46 guests
