ploquets
Filter Content in Firewall with DOT (.) in string
Fri Sep 03, 2021 3:44 am
Hello
I want to match DNS content with the content filter in advanced firewall rule tab.
But when I use with some dot, like,
example.com
it stops to match the string.
Sometimes it matches, but much less than normal scenario.
If I tried to use regex, like
example\.com
things get even worse.
Do someone know how to use dot in content filtering?
sindy
Re: Filter Content in Firewall with DOT (.) in string
Fri Sep 03, 2021 4:57 pm
It doesn't work because the dot symbol is not actually present in the DNS query - the FQDNs are encoded in a rather complicated way, see the RFC for DNS for details. There are multiple topics regarding this here on the forum, e.g, this post gives you a hint.
msatter
Fri Sep 03, 2021 5:18 pm
For non-dns traffic you could try example\\.com
ploquets
Sat Sep 04, 2021 2:49 am
When I try to use the example from the thread you linked, its not working as well.
Maybe there is difference between using L7 Filters and Content Filter
rextended
Sat Sep 04, 2021 3:28 am
Content filter parameter can be only a string, and on dns packet the dot do "not exist".
Understand this?
Layer7 filter can be a POSIX RegEx like (I do not write that filter!!!...)
^.?.?.?.?[\x01\x02].?.?.?.?.?.?[\x01-?][a-z0-9][\x01-?a-z]*[\x02-\x06][a-z][a-z][a-z]?[a-z]?[a-z]?[a-z]?[a-z]?[a-z]?[a-z]?[a-z]?[a-z]?[a-z]?[a-z]?[\x01-\x10\x1C][\x01-\x04\xFF]
TLS host matcher can be a POSIX RegEx like
(^|\.)youtube\.com$
ploquets
Mon Sep 06, 2021 10:09 pm
Understand this?
So what that means? Should I use space instead of dot ?
rextended
Mon Sep 06, 2021 10:22 pm
As @sindy already answer you on post #2 (!)
Inside the dns packet the dot between fields do not exist (like the dot in www.youtube.com)
Exist only if the field is exactly 46 characters long like:
³www .this-string-have-a-lenght-fourtysix-characters ³com
And the space exist only if a field with exactly 32 characters exist, like:
³www (space)string-with-lenght-of-thirty-two ³com
i have used the ³ sign because the character wit hex code 03 is not representable.
HEX 3 = ETX (Ctrl-C) END OF TEXT
sindy
Mon Sep 06, 2021 10:27 pm
No. You have to use a byte whose value is the length of the subsequent part of the domain name, example:
\08somename\03com
I don't remember the encoding of byte values exactly, I just remember it differs between regexp (used in layer7 rules) and contents. Check the manual.
rextended
Re: Filter Content in Firewall with DOT (.) in string  [SOLVED]
Mon Sep 06, 2021 10:31 pm
You have already wrote how are encoded, but on winbox you can not insert special characters like the character "\08", but can be added on CLI like:
add action=log chain=prerouting content="\03www\06google\03com"
ploquets
Thu Sep 09, 2021 10:28 pm
\08somename\03com
But is it "\x08" or only "\08" ?
rextended
Thu Sep 09, 2021 10:29 pm
(duplicate)
ploquets
Check the manual.
Which manual do you reffer?
rextended
Thu Sep 09, 2021 10:33 pm
Read my example on my previous post #9
viewtopic.php?f=2&t=178151#p877609
ploquets
Thu Sep 09, 2021 10:39 pm
OOWWW I see, when I tried to insert using terminal, the code gets different when viewing in winbox.
Got it.
rextended
Thu Sep 09, 2021 10:40 pm
You understand why now ;)
On all regex field and on terminal, RouterOS support only \1F hexadecimal characters rapresentation,
with hexadecimal letters uppercase and without the "x" (like wrong \x1F for RouterOS)
But you can use 0x for hexadecimal numbers on scripts, like:
:put (1 + 0x1F)
32
ploquets
Fri Sep 10, 2021 2:42 am
:put (1 + 0x1F)
32
How can I match content with hex DNS flags ?
like 0x8105 which means Refused ?
only contents="\8105" ?
rextended
Fri Sep 10, 2021 2:50 am
please explain, i do not have understand what you want do.
0x8105 are two bytes, 0x81 and 0x05
the conversion is "\81\05", but if on the field on the packet is on reverse order is "\05\81"
ploquets
Fri Sep 10, 2021 3:09 am
Trying to achieve the objective to drop responses with DNS Refused, as RFC1035 inform us.
The code is suposed to be 5
https://www.rfc-editor.org/rfc/rfc1035#section-4.1.1 -> see page 27
I see this 0x81 in some anti DDoS systems, like NSFocus. I guess is because (see page 26,27):
8 = RA
Recursion Available - this be is set or cleared in a response, and denotes whether recursive query support is available in the name server.
1 = QR
A one bit field that specifies whether this message is a query (0), or a response (1).
But I don't know if I am correct.
rextended
Fri Sep 10, 2021 3:14 am
RA is not 8, is th 8th bit set to 1
IS too late to explain better, but the 2 BYTEs are
10000000 10000101 = 80 85
ploquets
Fri Sep 10, 2021 3:19 am
I'm trying to understand how to block this messages:
https://routley.io/posts/hand-writing-dns-messages/
This blog kinda helps.
ploquets
Sat Sep 24, 2022 10:24 pm
@rextended
Can you please help me how to match DNS answers which has QTYPE (query type) = 255 (FF in HEX) ?
I've tried to match with content="\00\f\f" but this is not working.
rextended
Sun Sep 25, 2022 4:20 am
why \f\f ??
\f\f = \0f \0f
FF is \ff
QTYPE 255 is \00\FF and on reverse order \FF\00
Users browsing this forum: Bing [Bot], ichyre and 37 guests
