dmfr
V7 : Ping return as watchdog / scripting
Fri Sep 03, 2021 5:42 pm
Found a divergence in /ping command output between V6 and V7.
Consider an unreachable IP address (10.99.99.99) and script sentence to return TRUE if actually unreachable :
[admin@mtk-V6] > :put ([/ping count=4 address=10.99.99.99]=0)
true
[admin@mtk-V7] > :put ([/ping count=4 address=10.99.99.99]=0)
false
Thing is, V7 ping does not return explicit 0 when nothing pings. It just returns nothing/null.
Workaround :
[admin@mtk-V7] > :put (!([/ping count=4 address=10.99.99.99]>0))
true
Is it expected behavior ?
If V6 behavior cannot be restored, it means a lot of watchdog scripts needs fixing.
mTvGqH2
Re: V7 : Ping return as watchdog / scripting
Sat Jan 08, 2022 12:04 pm
I think your workaround doesn't solve the problem, isn't it?
It always returns true.
[admin@router] > :put (!([/ping count=1 address=8.8.8.8]>0))
Columns: SEQ, HOST, SIZE, TTL, TIME
SEQ  HOST     SIZE  TTL  TIME
  0  8.8.8.8    56  118  9ms973us
true
[admin@router] > :put (!([/ping count=1 address=8.8.8.1]>0))
Columns: SEQ, HOST, STATUS
SEQ  HOST     STATUS
  0  8.8.8.1  timeout
true
Any other hints how to use the result of "ping" in a script with v7 ?
michaelj
Tue Jan 11, 2022 4:43 pm
I found out that in V7 you can use the parameter "as-value". This converts the result to a string.
Furthermore I found out that the "Status" column only is filled out when the ping has failed. I can be wrong on this but I couldn't create a scenario where there was connection while status was filled out.
We can therefore use the status column (or lack of) to determine if there is connection or not
:put ( [/ping address=8.8.8.8 count=1 as-value]->"status"=null)
true
:put ( [/ping address=8.0.0.0 count=1 as-value]->"status"=null)
false
as-value is NOT available in V6 for the ping command
Hope this helps
Users browsing this forum: ak42 and 50 guests
