syadnom
Forum Veteran
Forum Veteran
NP16 v7rc2 reboot
Fri Sep 03, 2021 8:03 pm
NP16, rc2, BGP and hardware routing enabled. I had a random reboot this morning. no apparent cause or symptoms before the reboot. This is bone stock except added BGP, enabled romon, set some IP addresses. No queues, no vlans, only the most basic firewall rules on input chain, no NAT.
I just enabled error and critical logs to write to disk, anything else I should collect to identify what happened?
raimondsp
Re: NP16 v7rc2 reboot
Mon Sep 06, 2021 10:28 am
You can report the issue to our support. Also, check if RouterOS has generated autosupout.rif (via /file/print).
Users browsing this forum: No registered users and 31 guests
