Hi!
I have two wAPac (older ones), one of them is the WiFi GW the other is a repeater like AP.
Topology: [wired LAN]==={wire}===[AP1]---(((wifi 5GHz)))---[AP2]---)))---WiFi clients
I use AP2 to extend the wired & wireless LAN with WiFi-WDS. There is a static WDS between the two AP. On AP1 the WLAN & WDS interfaces are connected to a bridge which is vlan-filtering, but tagging enabled only on WDS, not on main WLAN interfaces.
This setup worked fine with ROSv6, but I upgraded my whole LAN to ROSv7.1RC1, and after some days the WDS traffic stops. In AP1's WL connection table, I see AP2, but there is no traffic goes through WiFi, except the neighbor discovery packets, as I see AP2 in the neighbor table. I tried mac-telnet to the AP2 MAC's but can't connect.
The traffic starts after I disconnect AP2 (remove AP2 from AP1 WL connection table). I upgraded to v7.1RC2 but traffic still stops.
What should I do?
