r0berts
Chateau LTE12 - signal / antenna query
Mon Sep 06, 2021 2:26 pm
I have a Chateau router bought in Latvia; it works well. I moved to an area in London that has patchy coverage for 3(IDnetwork) and LTE speed is on the low side.
My question is: is there a Mikrotik LTE antenna(s) that could help me get a better signal instead of MANT-50 that I am using at the moment? Or is there something else that I should try?
Signal parameters in good circumstances are about:
              rssi: -65dBm
              rsrp: -100dBm
              rsrq: -14dB
              sinr: -2dB
Speed as measured by speedtest-cli reports about 6 Mbit/s download and 3.5 Mbit/s upload. Speeds and signal can get a bit better or worse, but netflix and amazon video both work quite OK.
I installed MikrotiK mANT-50 antenna with Mikrotik Pro Mount on my window outside on glass using suction cups. That allowed me to orient the antenna the best way (judging by RSRQ and SNR changes) - as you can see on the picture. The SMA cable is a bit long - 5 m, but I will get it shorter in a week's time by using a window pass-through 50 cm cables connected to the MT 1 m cable. Paradoxically the tower seems to be behind the antenna (more on that later)
The connected tower data from CellMapper is:
eNB ID 7639 - LTE
MCC/MNC/Region:  234/20/1088
Cell Identifier: 1955585
System Subtype:  LTE
PCI: 403 (134/1)
Bandwidth: 15 MHz
EARFCN:  1392
Maximum Signal (RSRP): -99 dBm
Direction: S (166°)
First Seen:  Wed, 3 Feb 2021
Last Seen: Mon, 31 May 2021
Bandwidth*:  15 MHz
Uplink Frequency:  1729.2 MHz
Downlink Frequency:  1824.2 MHz
Frequency Band  DCS: (B3 FDD)
Judging from cellmapper data the tower is actually somewhere behind the antenna (and the building). It should be about 850 m away in straight line. The other mast should be about 700 m away in front of the antenna (should be eNB ID 5277 - LTE as from CellMapper), but Chateau seems not to be connecting to it at all; the only cell id I have seen in the router is 1955585. I do have windows on the other side of the building as well; however average speedtest values were worse on that side.
The modem is updated:
[admin@MikroTik] > /interface/lte/firmware-upgrade lte1
  installed: EG12EAPAR01A10M4G
     latest: EG12EAPAR01A10M4G
The system is updated as well:
[admin@MikroTik] > /system/resource/print
                   uptime: 58m41s
                  version: 7.1rc2 (testing)
               build-time: Aug/31/2021 08:07:46
Any ideas would be appreciated. Thanks!
Roberts
SiB
Re: Chateau LTE12 - signal / antenna query
Mon Sep 06, 2021 4:01 pm
mANT-50 is omnidirectional from nature. this is not a Directional antenna :(
Try for a few minutes take Chateau12 outsite window and check then what he connect with internal antennas.
Your RSRP ~100 is not good. SINR is not >5 and current result is like is.
In my opinion other directional antenna can improve situation.
r0berts
Mon Sep 06, 2021 10:00 pm
Thanks, this is what I also thought.
But how to choose an antenna? Or is there a recommended model for a situation like that.
Best wishes,
Roberts
SiB
Mon Sep 06, 2021 11:41 pm
r0berts
Tue Oct 19, 2021 10:58 pm
Thanks SiB,
Your replies were very helpful. I researched cell tower proximity, did a little wardriving and changed the network provider. M-ANT50 omnidirectional was giving quite good reception as well with
              rssi: -65dBm
              rsrp: -96dBm
              rsrq: -11dB
              sinr: 2dB
But then I attached Poynting directional antenna and it feels rather better:
              rssi: -56dBm
              rsrp: -86dBm
              rsrq: -12dB
              sinr: 8dB
Curiously speedtest results were quite similar. But I decided to keep the directional antenna installed; I think it is going to give more stable connection. I know the tower is 300 m away, maybe just a few trees in the direct line of sight. An interesting thing is that the near tower is used for CA band, the primary band comes from a more distant tower which is also obscured by my building.
And last note - with vodafone mobile provider if Use Network APN was checked, the internet would not work. Only when APN provided manually and the Use Network APN was off.
Users browsing this forum: No registered users and 42 guests
