mafiosa
high cpu usage while using BGP filters.
Tue Sep 07, 2021 6:27 pm
I am running two BGP sessions on my Rb3011 with v7.1 RC3. However I see that memory usage is 10 times more than on v6.48.3 and cpu usage is 20-30% more than before. Earlier it would be just 10% with occasional spikes to 25% max but now it is 56%+ all time. I am attaching a supout.rif file and config export as well.
rextended
Re: high cpu usage while using BGP filters.
Tue Sep 07, 2021 6:29 pm
Where you get the 7.1rc3?
Actually is like do not exist...
mafiosa
Tue Sep 07, 2021 6:44 pm
From support. Same issue exists on rc2 also.
mafiosa
Mon Sep 13, 2021 4:34 pm
Still no word from support, provided them multiple supout.rif files and configuration. Yet no reply from them. Atleast acknowledge the problem if it cannot be resolved.
SUP-59730
Users browsing this forum: No registered users and 6 guests
