stefanosp
DoH overrides DNS Static RegEx
Wed Sep 08, 2021 2:08 am
I've found (in 6.48.4 and in LongTerm 6.47.10) that if I setup a DoH server (in my case, NextDNS), DNS static entries of type "FWD" stops working
If I remove DoH server and setup a "normal" DNS server (like 1.1.1.1), DNS FWD static entries work normally.
is this normal behavior? if yes, is there a workaround to make DoH and DNS FWD work together? Thank you
stefanosp
Re: DoH overrides DNS Static RegEx
Mon Sep 13, 2021 11:17 pm
would anyone have any ideas to help me please? :)
Thank you
dhoulbrooke
Trainer
Trainer
Tue Sep 14, 2021 11:40 am
Unfortunately yes this is the expected behaviour:
Currently, DoH is not compatible with FWD-type static entries, in order to utilize FWD entries, DoH must not be configured.
https://help.mikrotik.com/docs/display/ ... HTTPS(DoH)
eworm
Tue Sep 14, 2021 6:51 pm
I am suffering this issue as well...
Would be nice if Mikrotik could repair it.
rextended
Tue Sep 14, 2021 7:49 pm
The problem is the FWD itself...
If DoH is used, is a nonsense use unsigned FWD replies...
Is why on help page is clearly indicated...
eworm
Tue Sep 14, 2021 11:30 pm
I can forward to DNS servers that are in my LAN or accessible via VPN... No leakage of sensitive information there.
stefanosp
Thu Sep 16, 2021 10:58 pm
exactly my setup.
I found the entry in the Help Page at https://help.mikrotik.com/docs/display/ROS/DNS
The term "Currently" makes me hope for the future.
stefanosp
Sat Sep 18, 2021 7:52 pm
To bypass the problem, I'm using 2 Routerboards in the same LAN
in the first router, DNS is configured with FWD entries and /ip dns set servers=<the second MIkrotik's IP>
in the second one, DNS is configured with DoH.
It works.
Florian
Sat Sep 18, 2021 9:14 pm
It works.
I do that too, but tbh it should work with only one device :D
j4c3k
Mon Nov 22, 2021 4:24 pm
I'm also facing this issue. RouterOS v7. It's already few releases happen... I hope it will be fixed soon...
mode
Tue Jun 21, 2022 11:23 am
Any progress on this?
eworm
Tue Jun 21, 2022 3:23 pm
Sadly: No.
Users browsing this forum: 3dfx, Bing [Bot], netmas, pants6000 and 216 guests
