emils
Forum Veteran
Forum Veteran
WinBox v3.30 released!
Thu Sep 09, 2021 6:12 pm
What's new in v3.30:
*) added support for mouse wheel scroll in field & table show columns windows;
*) double click on word in "Terminal" now automatically selects and copies it to clipboard;
*) fixed WinBox disconnect when selecting entries in QuickSet's "WiFi Clients" table;
*) fixed crash when all inner windows were closed;
*) fixed crash when opening some of interfaces;
*) fixed glitches while resizing column widths or reordering table entries;
*) fixed visual glitch when showing table filters and categories;
*) fixed visual glitches when scrolling "Terminal" window and Zoom In or Zoom Out is used;
*) made Ctrl++ & Ctrl+- still work if focus is on checkbox;
*) made Ctrl+C and Enter right after text selection in "Terminal" window work as copy to clipboard;
*) made Ctrl+D pass-through to "Terminal", so it is possible to terminate inner telnet or SSH sessions;
*) made Ctrl+V work as paste from clipboard;
*) made double click in "Torch" window work again;
*) properly show "I" flag for invalid entries;
*) use router's time when filling default time in "Scheduler" items;
If you experience version related issues, then please report them to support@mikrotik.com.
Both Winbox 32-bit and 64-bit versions are available here:
https://www.mikrotik.com/download
rextended
Re: WinBox v3.30 released!
Thu Sep 09, 2021 6:18 pm
from 3.28 changelog
*) fixed WinBox disconnect when large text was pasted into terminal window;
This bug introduced on 3.28 is still present:
viewtopic.php?f=21&t=175783#p862289
Thanks for swap back Close and Stop, but:
is not better use one unique [Start | Stop] button, like [Simple Mode | Advanced Mode] on Wireless interface???...
(probably now some user complain about swap because they got addicted to the new position :lol: :lol: :lol: )
BartoszP
Thu Sep 09, 2021 6:23 pm
Seems that Start/Stop/Close buttons placement&order is back.
freemannnn
Forum Veteran
Forum Veteran
Thu Sep 09, 2021 6:30 pm
can you fix cloud backup time not shown correctly. i run every day at 0300 and it says 0000. i think cloud backup window does not use correct time zone.
rextended
Thu Sep 09, 2021 6:33 pm
Timezone of cloud server? +03:00
Your???
freemannnn
Forum Veteran
Forum Veteran
Thu Sep 09, 2021 6:40 pm
my timezone is setup correctly +0300. also time on dashboard top right is showing correctly. only cloud backup window has wrong time shown.
i run the script manually now and it should says backup time 18:44 but it says 15:44
pe1chl
Thu Sep 09, 2021 7:29 pm
YES, this annoying problem that was present ever since version 3.22 has finally been fixed! Hooray! Finally I can use new versions again.
(I had already received 3.30rc versions this week so I knew it was fixed...)
Another (less) annoying problem I reported is still present: the column width is not saved in the Log window.
Whenever I open a new session, the Log window has the same column width as before, although window size and "Show columns..." are saved OK.
So on my large screen the Message column is truncated and I need to resize it to see the full message, for which there is ample space.
It would be nice when the set column width is saved, and even nicer when the Message column automatically takes all remaining space instead of having a blank column to the right of it (but that is of course true for all windows...).
Railander
Thu Sep 09, 2021 8:02 pm
is this the one where if you were dragging an entry in routing filters, it'd keep being sent down to the last position even though you were still holding the mouse button?
if so, thank god.
pe1chl
Thu Sep 09, 2021 8:09 pm
if so, thank god.
Yes, that is it! It was reported over and over again and dismissed with "we cannot reproduce it" until finally this week, after I sent a .viw file and provided access to our router they were able to reproduce it and it was fixed.
Indeed a critical fix, without this the use of winbox on routers with lots of configuration was outright dangerous!
fs0c13ty
Thu Sep 09, 2021 8:45 pm
msatter
Thu Sep 09, 2021 8:48 pm
Many MANY thanks:
One thing, when I use Ctrl+c it generates an automatic "carriage return" in Terminal . Not handy when you are copying in the same line.
Please split Ctrl+C and select+Enter.
Update: behavior is a bit strange for the Enter. [SUP-60072]
Example, I like for testing scripts to paste it into terminal and I put it between {.....} and then press Enter to start the script. Now I have to press twice Enter before the script is ran. This has to if you add comment to script.
One Enter needed:
{:put "test"}
Two Enters needed:
{# running a test;
        :put "test"}
Ctrl-C is also tricky. I have text on the clipboard but in terminal still waiting for excution of the script. Because of a syntax error display I want to past the the corrected script so I press Ctrl-C to exit. Oops now is the clipboard empty.
thims
Thu Sep 09, 2021 9:35 pm
IP/Firewall:
Zacharias
Thu Sep 09, 2021 10:35 pm
If you press ctr + D when the terminal is open ( without an active SSH / telnet connection ), the terminal closes and the next terminal that will open continues from the previous number + 1...
For example, if you open terminal1 and press ctr + D, the terminal closes, if you open again Terminal2 appears not Terminal 1 ...
Cha0s
Fri Sep 10, 2021 12:40 am
Thank you so much for fixing this! I can also, finally use new WinBox versions again! :)
abis
Fri Sep 10, 2021 12:58 am
Yea, I dont know why they don't put the buttons bottom and verticaly, in that way will be alots of space for text :)
IP/Firewall:
infabo
Long time Member
Long time Member
Fri Sep 10, 2021 1:28 am
As a new user of Mikrotik I wonder, how a software that looks 1:1 the same on screenshots on some MUM slides from 2013, has still so many bugs to fix in 2021.
kuz8
Fri Sep 10, 2021 1:38 am
While it's possible to resize the column selector dialog, I wasn't able to make IP - Firewall - NAT column "To Addresses" to show - I set a checkmark, instead other column shows in the list but not the "to addresses" - repeatedly:
ccanto
Fri Sep 10, 2021 2:33 am
Yes, that problem seems to also be present in others lists as well.
Try "Interface List" -> "Ethernet" and select only the first 5 columns and any one at the end like "Tx Unicast".
I see that another random column got selected.
Now if I remove the "Tx Unicast" and select another one at random, winbox showed a bunch of random columns (but not the one I wanted)
nichky
Fri Sep 10, 2021 4:48 am
on bgp , show columns doesn't work for in and out filter, one always missing
chechito
Fri Sep 10, 2021 6:43 am
good news thank you for the info, updating now
tarikin
Fri Sep 10, 2021 8:31 am
Queues -> simple
Weird column selection behavior, please fix
Example:
Selecting Dst in the columns list - > no effect
Unselecting Target in the columns list - > no effect
Copy-paste hotkeys and double-click selection works great even on M1 mac, thank you!
tarikin
Fri Sep 10, 2021 8:38 am
Looks same, works different. Just zoom-in! New features always comes with new bugs. Product development cycle.
IMHO MikroTik relies a lot on the crowdsource community for final-testing stable releases before it goes into a long-term branch.
Don't like bugs? Use long-term releases.
infabo
Long time Member
Long time Member
Fri Sep 10, 2021 12:24 pm
There is no long-term release for Winbox. These bugs were either a) always there and long time not discovered or b) are simple regressions because of e.g. some new column-drag-drop-feature.
oskarsk
Fri Sep 10, 2021 1:02 pm
Thanks for the reports, we are aware of the column issue, that it does not save properly.
pe1chl
Fri Sep 10, 2021 2:07 pm
When you need some very stable version without recent features but without some known problems, try version 3.21
It will still work with all version 6 RouterOS (but not with the v7rc3).
hapi
Fri Sep 10, 2021 2:16 pm
Show columns in OSFP / instance. After select "Effective Router ID" is showing other columns. Unselect columns (in/out filter) not work. It doesn't work properly in other places either. (wireless tables / registration)
pe1chl
Fri Sep 10, 2021 2:33 pm
Did you not read message #25 by oskarsk?
No need to add a "me too!" reply for the same fault over and over again.
anav
Fri Sep 10, 2021 5:39 pm
Just switched over to 3.30 TY, TY , TY , TY. I can now /export my config in terminal and it is fully visible scrolls well and doesnt not get overlapped on lines. TY, TY
(note: reg firmware not beta)
w0lt
Long time Member
Long time Member
Fri Sep 10, 2021 5:53 pm
I'm seeing this myself. I try and delete columns and they just return, sometimes with additional unselected columns .
ROS 7.1rc3
Winbox 3.30
pe1chl
Fri Sep 10, 2021 6:45 pm
ROS 7.1rc3
Winbox 3.30
mducharme
Trainer
Trainer
Fri Sep 10, 2021 7:06 pm
Just a caution - if you even just click OK in the show columns window without changing anything, it will still change what columns are displayed even though you haven't actually made any changes. You don't have to select or deselect anything to trigger this bug, apparently.
w0lt
Long time Member
Long time Member
Fri Sep 10, 2021 7:16 pm
ROS 7.1rc3
Winbox 3.30
Really. 😵‍💫
ErfanDL
Fri Sep 10, 2021 8:01 pm
and again there is no dark mode feature in this release :)
Zacharias
Fri Sep 10, 2021 8:35 pm
If i select to-adresses or to-ports and click ok, it changes the column width of every column and it never adds neither to-adresses nor to-ports in the columns ...
anav
Fri Sep 10, 2021 11:17 pm
What is interesting to me is introducing new software changes, often breaks existing code or introduces a whole new set of bugs................. Good lesson for any testers out there...
chechito
Sat Sep 11, 2021 12:23 am
happened to me and enabled other columns not selected
rextended
Sat Sep 11, 2021 12:30 am
Disabling all execpt one, I obtain muiltiple random selections...
(on IP Firewall NAT)
anav
Sat Sep 11, 2021 3:17 pm
In other words 3.31 is not far around the corner!!
Zacharias
Sat Sep 11, 2021 4:11 pm
I hope so.. The fact that i can't use the Column Lists properly will make me use 3.29 ...
Renfrew
Sat Sep 11, 2021 6:07 pm
Stupidly, when I installed v3.30 I forgot to keep a copy of v3.29. I reported the issues with columns to support on Thursday but their software archive doesn't have copies of previous version of winbox, that I can find.
Could someboy kindly point me to a trustworthy site for downloading v3.29 ? Many thanks in anticipation.
Zacharias
Sat Sep 11, 2021 6:14 pm
viewtopic.php?t=165563
Xtreme512
Sat Sep 11, 2021 7:55 pm
new column select window is nice but it doesn't show the selected column, instead shows other unnecessary columns; making a mess.
Renfrew
Sat Sep 11, 2021 8:13 pm
Thank you.Fairly obvious when you know it!
felodimul
Sun Sep 12, 2021 7:51 pm
I'm having this "random columns appear and reappear" problem, in the DHCP Server window. I can't figure out how to select the columns I want to see, because my selections in the Columns window has no effect on what happens in the DHCP Server window. I can't detect any pattern in it. Sometimes columns disappear, sometimes they appear, but they never seem to do what I ask!
fs0c13ty
Mon Sep 13, 2021 2:03 pm
in router os v7.1rc3 when clicking on + sign in interface list and selecting virtual for creating virtual ethernet it will open wireless window and there is no virtual ethernet menu despite of ROS v6.
when you create veth and assign ip from terminal. ip and gateway does not show in interface window when double click on it.
pe1chl
Mon Sep 13, 2021 4:14 pm
You may want to reconsider if it is a good idea to "always work in safe mode", especially when you have reconnections.
Safe mode is a nice feature when you want to change critical connectivity-related parameters, but when you have it enabled all time time it may do more bad than good.
rextended
Mon Sep 13, 2021 5:20 pm
I have described on another topic how to schedule a auto-reload backup when starting critical procedures than inevitably disconnect winbox and safe mode clear all work done.
corp9592
Mon Sep 13, 2021 9:19 pm
+1
I am seeing this in the bridge column selector. The more I try to select some subset of columns, WinBox ends up choosing for me.
pthunya
Trainer
Trainer
Tue Sep 14, 2021 9:07 pm
Found problem column selection not work correction as attached video. :)
https://youtu.be/2G5LjWG_0xc
raffav
Wed Sep 15, 2021 11:55 am
I think should adopt 3rd dot for bug fix
3.30.x
Like the same way is for ROS
pe1chl
Wed Sep 15, 2021 12:15 pm
Why? After this flurry of new releases due to introducing bugs in new features, the version could again be stable for a year or even two.
rushlife
Wed Sep 15, 2021 12:29 pm
+1
I found this when I want see current channel in Caps interface window....
rextended
Wed Sep 15, 2021 5:20 pm
Before post, read what already posted if some problem is already noticed, and the download link... read what already posted
JJT211
Thu Sep 16, 2021 4:41 am
Im having same exact issue
Maggiore81
Trainer
Trainer
Thu Sep 16, 2021 11:58 am
Bug: in interface list I want to select RATE, it returns back and adds automatically IPSEC Policy....
emils
Forum Veteran
Forum Veteran
Thu Sep 16, 2021 12:16 pm
WinBox v3.31 released:
viewtopic.php?f=21&t=178584
Users browsing this forum: DenisPDA, nescafe2002, onnoossendrijver and 52 guests
