CTassisF
RIPE Atlas Software Probe running on v7.1rc3 [development]
Sat Sep 11, 2021 3:17 am
Now that RouterOS v7.1rc3 supports running containers, I took the time to create a Docker image to run RIPE Atlas Software Probe on my MikroTik router.
The image is based on the official code provided by RIPE NCC, with a few tweaks to make it run under Alpine Linux. Alpine is based on musl, not glibc, and that makes the image a lot smaller and faster to run in containers. I'm currently running it on my hAP ac³ and it is working great :D
To use this image is very simple:
# Create veth interface
/interface/veth/add address=172.16.0.1/24 gateway=172.16.0.254 name=veth1
# Create bridge interface
/interface/bridge/add admin-mac=00:53:FF:1A:2B:3C auto-mac=no mtu=1500 name=bridge-docker
# Add IPv4 to bridge
/ip/address/add address=172.16.0.254/24 interface=bridge-docker
# Add veth to bridge
/interface/bridge/port/add bridge=bridge-docker ingress-filtering=no interface=veth1
# Add bridge to LAN (so it can do NAT)
/interface/list/member/add interface=bridge-docker list=LAN
# Create mounts for /var/atlas-probe/etc and /var/atlas-probe/status
/container/mounts/add dst=/var/atlas-probe/etc name=atlas-probe-etc src=atlas-probe-etc
/container/mounts/add dst=/var/atlas-probe/status name=atlas-probe-status src=atlas-probe-status
# Create container
/container/add dns=172.16.0.254 hostname=ripe-atlas interface=veth1 mounts=atlas-probe-etc,atlas-probe-status root-dir=ripe-atlas start-on-boot=yes remote-image=ctassisf/ripe-atlas-alpine:latest
# Start container
/container/start number=0
# Check if container is status=running
/container/print
Use the public SSH key probe_key.pub saved in your router's storage to register your probe here: https://atlas.ripe.net/apply/swprobe/
And then let me know if it worked for you :)
This is still a work in progress. Maybe there's something not quite right. I'm also interested in making IPv6 work (either natively or through NAT) but I wasn't able to do so yet.
You can see my probe running here. I'm also attaching some screenshots showing how my hAP ac³ is handling the load (it doesn't make a dent lol).
Project is available on GitHub and Docker Hub.
More info can also be found on MikroTik Documentation.
normis
Re: RIPE Atlas Software Probe running on v7.1rc3 [development]
Sat Sep 11, 2021 10:37 am
Thanks for the tutorial!
vovailchenko
Thu Dec 01, 2022 6:58 pm
Hello CTassisF
Thank you for the tutorial.
I've tried it and it works like a charm - until a reboot.
After reboot - i can not start the container. webfig/winbox/cli - nothing works. nothing happens - no messages. and container is still stopped. there are no messages in the log (logging is enabled on the container and as a topic in /system/logging).
I'm storing the image tar-file, as well as mount-points on the external USB-stick (ext4 fs). I'm using hap ac^2.
Have you ever encountered anything like this? I saw some messages on the forum, but those bugs were resolved in 7.5betax - i'm using 7.6 stable now.
Maggiore81
Trainer
Trainer
Sun Feb 26, 2023 7:24 pm
News on this topic?
CTassisF
Mon Feb 27, 2023 3:33 am
These images continue to work fine with my MikroTik devices (RB5009 (arm64) and hAP ac³ (arm)).
By the way, I recently updated the instructions above to reflect the new images available in Docker Hub.
Please let me know if you're still having issues with ctassisf/ripe-atlas-alpine.
Mitar
Sun May 07, 2023 12:49 am
It works great on Hap AX2, BUT I have noticed that there is a lot of writes to the disk and its due to atlas probe writing constantly temporary data to \var\atlasdata
I think it would be best to mount \var\atlasdata as 32 MB tmpfs so that internal flash drive wouldn't die too soon.
I have measured that without tmpfs it does 300 000 sector writes DAILY, so its safe to assume it could kill Mikrotik flash in just a few months, same goes for lower quality pendrives.
Temporary solution that I have found is to make ramdisk on mikrotik because doing it from container itself turned out to be harder than I thought without running container as root.
1) Create 32MB ramdisk on mikrotik :
/disk add type=tmpfs tmpfs-max-size=33554432 slot=atlasdata
2) Mount that ramdisk to a container :
/container/mounts/add dst=/var/atlasdata name=atlasdata src=atlasdata
GreDi
Sun Jan 21, 2024 11:33 pm
model: RB4011iGS+
current-firmware: 7.13.2
Your probe is currently connected! 8)
Thx U @CTassisF
baragoon
Mon Jan 22, 2024 9:29 am
Good job, will try at free time. My Altas probes runing on RPIs, maybe it's time to migrate :)
BTW, maybe you know a working solution of "looking glass" container for Tik devices?
Users browsing this forum: anav, GoogleOther [Bot], intania, sirbryan and 87 guests
