rinners
Wireless menu and wlan devices missing after update of SXTs to 6.48.4
Sat Sep 11, 2021 7:46 pm
I have 2 of the older SXTs and after updating to RouterOS 6.48.4 I can no longer access any wireless features.
Is there a way I can get access to older versions of RouterOS. I think they have 6.32.2 on before this.
cdemers
Re: Wireless menu and wlan devices missing after update of SXTs to 6.48.4
Fri Sep 17, 2021 3:56 am
That should work, I use many older SXTs still with current stable. Maybe upgrade the bios firmware and then try to net install them from scratch.
Elans
Re: Wireless menu and wlan devices missing after update of SXTs to 6.48.4  [SOLVED]
Fri Sep 17, 2021 7:06 am
@rinners
RouterOS stable/LT version archive - https://mikrotik.com/download/archive
However, it is not recommended to use an old RouterOS versions. In case there is a software related problems with your device, we do recommend to contact support directly.
mkx
Fri Sep 17, 2021 9:19 am
Verify the list of installed packages after upgrade ... under /system packages. Version number of all installed packages should match version number of system package. There should be a number of packages installed and enabled, package "wireless" should be among them.
Users browsing this forum: No registered users and 63 guests
