JancariusSeiryujinn
Unable to connect to hAC2 Wirelessly
Tue Sep 14, 2021 5:41 am
Hello. I have an RB4011 as my primary intranet router, a CRS326 serving as my main layer2 device, and 2 wireless devices - a hAC lite, and an hAC2.
The issue I'm having trouble with at the moment is I seem completely unable to get on the wireless networks of the hAC2. Even when I disabled WPA2 key requirements, I'm unable to connect. In the hAC2s logs, I don't even see evidence of that connection.
The hAC2 itself can ping the main router, out to the internet, etc. If I make a wired connection into one of the hAC2s ports, that works fine.
Edit: I determined that nstream was on and that's why the wireless connection was entirely failing. I now can see myself connect in the logs. However, my VID is 1, despite the PVID of the WLAN being 101.
# sep/13/2021 16:11:31 by RouterOS 6.48.4
# software id = IEWC-ASHD
# model = RBD52G-5HacD2HnD
# serial number = CDFC0EE28D33
add name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=vlan100 vlan-id=100
add interface=bridge1 name=vlan101 vlan-id=101
add interface=bridge1 name=vlan102 vlan-id=102
add interface=bridge1 name=vlan103 vlan-id=103
add name=WAN
add name=LAN
add authentication-types=wpa2-psk,wpa2-eap eap-methods="" mode=dynamic-keys name=Public supplicant-identity="" wpa2-pre-shared-key=MYKEY
add authentication-types=wpa2-psk,wpa2-eap mode=dynamic-keys name=Printer supplicant-identity="" wpa2-pre-shared-key=MYKEY
add authentication-types=wpa2-psk,wpa2-eap mode=dynamic-keys name=Networked supplicant-identity="" wpa2-pre-shared-key=MYKEY
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country="united states" disabled=no installation=indoor mode=ap-bridge security-profile=Public ssid=OuterHeaven-2.4 vlan-mode=use-tag \
    wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac disabled=no installation=indoor mode=ap-bridge security-profile=Public ssid=OuterHeavenTest vlan-mode=use-tag wps-mode=disabled
add comment="No-Internet VLAN103" disabled=no keepalive-frames=disabled mac-address=2E:C8:1B:A7:AF:FF master-interface=wlan1 multicast-buffering=disabled name=wlan3 security-profile=\
    Printer ssid=OuterPrinter vlan-id=103 vlan-mode=use-tag wds-cost-range=0 wds-default-cost=0 wps-mode=push-button-virtual-only
add comment="Internet-allowed security devices" disabled=no keepalive-frames=disabled mac-address=2E:C8:1B:A7:AF:FE master-interface=wlan1 multicast-buffering=disabled name=wlan4 \
    security-profile=Networked ssid=Foxhound vlan-id=102 vlan-mode=use-tag wds-cost-range=0 wds-default-cost=0 wps-mode=push-button-virtual-only
/interface wireless manual-tx-power-table
set wlan3 comment="No-Internet VLAN103"
set wlan4 comment="Internet-allowed security devices"
set *A comment="No-Internet VLAN103"
set *B comment="Internet-allowed security devices"
add name=dhcp ranges=192.168.0.50-192.168.0.99
/caps-man manager
set enabled=yes
add bridge=bridge1 interface=wlan2 pvid=101
add bridge=bridge1 interface=wlan1 pvid=101
add bridge=bridge1 interface=ether1 trusted=yes
add bridge=bridge1 interface=wlan3 pvid=103
add bridge=bridge1 interface=wlan4 pvid=102
add bridge=bridge1 interface=ether2 trusted=yes
/interface bridge vlan
add bridge=bridge1 tagged=ether1,bridge1 untagged=ether2,ether3,ether4,ether5 vlan-ids=100
add bridge=bridge1 tagged=ether1,bridge1 untagged=wlan1,wlan2 vlan-ids=101
add bridge=bridge1 tagged=ether1,bridge1 untagged=wlan4 vlan-ids=102
add bridge=bridge1 tagged=ether1,bridge1 untagged=wlan3 vlan-ids=103
/interface wireless cap
set interfaces=wlan2,wlan1
add address=192.168.100.202/24 interface=vlan100 network=192.168.100.0
add address=192.168.101.202/24 interface=vlan101 network=192.168.101.0
add address=192.168.102.202/24 interface=vlan102 network=192.168.102.0
add address=192.168.103.202/24 interface=vlan103 network=192.168.103.0
add address=192.168.0.0/24 gateway=192.168.0.0 netmask=24
add address=192.168.100.0/24 dns-server=192.168.0.1,8.8.8.8 gateway=192.168.100.1 netmask=24
add address=192.168.101.0/24 dns-server=192.168.0.1,8.8.8.8 gateway=192.168.101.1 netmask=24
add address=192.168.102.0/24 dns-server=192.168.0.1,8.8.8.8 gateway=192.168.102.1 netmask=24
add address=192.168.103.0/24 dns-server=192.168.0.1,8.8.8.8 gateway=192.168.103.1 netmask=24
set servers=192.168.0.1,8.8.8.8
add distance=1 gateway=192.168.100.1
add distance=1 gateway=192.168.101.1
add distance=1 gateway=192.168.102.1
add distance=1 gateway=192.168.103.1
/system clock
set time-zone-name=America/Denver
/system identity
set name=MikrotikWirelessMai
gotsprings
Re: Unable to connect to hAC2 Wirelessly
Tue Sep 14, 2021 1:29 pm
Something might be stripping the tag.
mkx
Tue Sep 14, 2021 11:28 pm
This problem is being dealt with in another thread, will just reply here for readers who might get here by chance.
No, it's not. OP has set vlan-mode=use-tag on wireless interfaces without explicitly setting vlan-id property. Implicit default setting is vlan-id=1 which means that the wireless driver tags frames with VID=1 ... bridge's pvid setting has no effect because wireless driver hands over tagged frames.
Users browsing this forum: GoogleOther [Bot], onnyloh, Plnt, tangent and 31 guests
