npeca75
Option39 DHCPv6 Client
Fri Sep 17, 2021 6:22 am
Hi to all
last night i realized that MKT does not have Option 39 in dhcp v6 client :(
so, here it is script implementation
#ascii chars
:local ascii1 ("0123456789")
:local ascii2 ("abcdefghijklmnopqrstuvwxyz")
:local ascii3 ("-")
:local ascii ($ascii1 . $ascii2 . $ascii3)
#ascii values
:local val1 "30,31,32,33,34,35,36,37,38,39,"
:local val2 "61,62,63,64,65,66,67,68,69,6a,6b,6c,6d,6e,6f,70,71,72,73,74,75,76,77,78,79,7a,"
:local val3 "2d"
:local val [:toarray ($val1 . $val2 . $val3)]
#hex chars
:local hex "0123456789ABCDEF"
:local hn  [/system identity get name]
:local hnld [:len $hn]
:global hout ""
:global tmp ""
:local cnt 0
:for pc from 0 to ($hnld-1) do={
    :local chr [:pick $hn $pc]
    :if ($chr != "." ) do={
        :local pa [:find $ascii $chr]
        :local hv [:pick $val $pa]
        :set tmp ( $tmp . $hv )
        :set cnt ($cnt + 1)
    } else {
        :local hnlh [:pick $hex $cnt]
        :set hout ( $hout . "0" . $hnlh . $tmp)
        :set cnt 0
        :set tmp ""
:local out ( "0x01" . $hout . "00")
:log info "$hn -> $out"
/ipv6 dhcp-client option set 0 value=$out code=39 name=option39
Script is not nice :) and does not make any check on hostname valid chars
so, only 0-9, a-z , hyphen and dot
OpenWRT odhcpd work well with this script, and wireshark dump confirm that packet is valid
so, mikrotik name is visible in DHCPv6 server
if someone want to improve / clean / rewrite this script ... :)
rextended
Re: Option39 DHCPv6 Client
Fri Sep 17, 2021 10:14 am
The script not work if the fqdn have one part with more than 9 characters, like www.thisismydomain.com
because the length on encoded dns when is bigger than 9 must be converted to hexadecimal, not "0" + ":len" as string
Why not simply:
add code=39 name=option-39 value="0x0108'test-mkt'0x03'lan'0x00"
Without use scripting?
npeca75
Fri Sep 17, 2021 11:28 am
hi @rexetended
www.thisismydomain.com -> 0x01037777770E7468697369736d79646f6d61696e03636f6d00
i dont see problem here
0x0F is maximum between dot's (15)
yes, it is limited, but not on 9 as you say
#hex chars
hnlh = length in hex
why script ?
Simple tryout to implement missing function
and maybe learn some about Option39, scripting, etc
rextended
Fri Sep 17, 2021 11:30 am
9 or 15, is limited, this not change the point
The max length for label and domain is 63 characters
rextended
Re: Option39 DHCPv6 Client  [SOLVED]
Fri Sep 17, 2021 11:32 am
search tag # rextended DHCPv6 option 39 fqdn2encdns FQDN to DNS encoding DNS encoder
I just finished to write this to directly encode the string:
:global fqdn2encdns do={
    :local charsString ""
    :for x from=0 to=15 step=1 do={ :for y from=0 to=15 step=1 do={
        :local tmpHex "$[:pick "0123456789ABCDEF" $x ($x+1)]$[:pick "0123456789ABCDEF" $y ($y+1)]"
        :set $charsString "$charsString$[[:parse "(\"\\$tmpHex\")"]]"
    :local chr2lcase do={
        :local chrValue [:find $2 $1 -1]
        :if (($chrValue > 64) and ($chrValue < 91)) do={
            :return [:pick $2 ($chrValue + 32) ($chrValue + 33)]
        } else={
            :return $1
    :local numbyte2hex do={
        :local input [:tonum $1]
        :local hexchars "0123456789ABCDEF"
        :local convert [:pick $hexchars (($input >> 4) & 0xF)]
        :set convert ($convert.[:pick $hexchars ($input & 0xF)])
        :return $convert
    :local input "$1"
    :local fqdn ""
    :local encdns "0x01''"
    :if ($input~"^(([a-zA-Z0-9][a-zA-Z0-9-]{0,61}){0,1}[a-zA-Z]\\.){1,9}[a-zA-Z][a-zA-Z0-9-]{0,28}[a-zA-Z]\$") do={
         :for y from=0 to=([:len $input]-1) step=1 do={
             :set fqdn "$fqdn$[$chr2lcase [:pick $input $y] $charsString]"
         :local workstr $fqdn
         :local dotidx  0
         :while ([:typeof [:find $workstr "." -1]] != "nil") do={
             :set dotidx [:find $workstr "." -1]
             :set encdns "$"encdns"0x$[$numbyte2hex $dotidx]'$[:pick $workstr 0 $dotidx]'"
             :set workstr [:pick $workstr ($dotidx + 1) [:len $workstr]]
         :return "$"encdns"0x$[$numbyte2hex [:len $workstr]]'$workstr'0x00"
    } else={
        :return ""
How to use, for example call it to put on terminal the ecncoded DNS
:put [$fqdn2encdns www.thisismydomainname.net]
0x01''0x03'www'0x12'thisismydomainname'0x03'net'0x00
Or like this:
set [find where code=39] value=[$fqdn2encdns www.thisismydomainname.net]
npeca75
Fri Sep 17, 2021 11:41 am
search tag #rextended fqdn2encdns FQDN to DNS encoding DNS encoder
after all, it was the whole point of my post
to learn, and to induce people to make it better
it is so sad that users need to implement missing features :(
rextended
Fri Sep 17, 2021 11:42 am
Yes, I hope you like my script....
rextended
Fri Sep 17, 2021 11:48 am
Bugfix:
Wrong
0x010x03'www'0x12'thisismydomainname'0x03'net'0x00
Correct:
Script fixed
npeca75
Mon Sep 20, 2021 1:02 pm
Hi
sorry for late reply
yes, it is working fine
tested on 6x and 7x
ok, two different approach for same problem :)
thank you
Users browsing this forum: No registered users and 8 guests
