gstubbe
Unable to advertise fixed prefix through output.network
Mon Sep 20, 2021 9:46 pm
I have upgraded a testrouter to see if I can transfer my v6 config to v7. My BGP session is established with my peering provider but I am not sending any prefixes even though it is configured:
/ipv6 firewall address-list
add address=2a0e:b107:1165::/48 list=RIPE_PREFIX_ipv6
/routing table
add fib name=""
/routing bgp connection
add address-families=ipv6 as=211184 disabled=no local.role=ebgp name=TEST \
    output.network=RIPE_PREFIX_ipv6 remote.address=<peer>/128 \
    .as=41051 routing-table=main
/routing filter rule
add chain=RIPE_OUT rule="if (dst == 2a0e:b107:1165::/48) {accept;}"
add chain=RIPE_OUT rule="reject;"
add chain=RIPE_IN rule="reject;"
The routing filter is there but currently unused. Is there a way I can check my advertisements through the cli in v7?
Session detail:
session/print
Flags: E - established
 0 E remote.address=<peer> .as=41051 .id=<id>
     .refused-cap-opt=no .capabilities=mp,rr,gr,as4,ap,fqdn .afi=ipv6
     .messages=40507 .bytes=5070845 .gr-time=120 .eor=""
     local.address=<local> .as=211184 .id=<id>
     .capabilities=mp,rr,gr,as4 .afi=ipv6 .messages=5 .bytes=95 .eor=""
     output.procid=23 .network=RIPE_PREFIX_ipv6
     input.procid=23 ebgp
     hold-time=3m keepalive-time=1m
version:
/system/package/print
Columns: NAME, VERSION
# NAME      VERSION
0 routeros  7.1rc4
gstubbe
Re: Unable to advertise fixed prefix through output.network
Mon Sep 20, 2021 10:32 pm
I have been playing around in GNS3 and notice that I am unable to send any route (connected, static,...) if output.network is defined as above. When I do define it, it does not advertise the defined network nor the option under output.redistribute.
mrz
Mon Sep 20, 2021 10:46 pm
You need corresponding igp route in the routing table, otherwise networks will not be advertised. Think of it like v6 BGP networks with always enabled synchronization.
gstubbe
Mon Sep 20, 2021 11:49 pm
Is there any equivalent to the bgp networks without synchronization from V6?
mrz
Re: Unable to advertise fixed prefix through output.network  [SOLVED]
Tue Sep 21, 2021 12:27 am
no.
Users browsing this forum: qwertykolea and 51 guests
