CuriousKiwi
LtAP WiFI connector labelling
Tue Sep 21, 2021 12:17 pm
Can anyone tell me which of the MMCX connectors is chain 0 and which is chain 1?
Also, between the built in antennas and the MMCX connectors, which is antenna A and which is antenna B?
I have a single chain, low bandwidth application so only want to use one chain, but don't want to accidentally enable the wrong one and damage the output circuitry
ConnyMercier
Forum Veteran
Forum Veteran
Re: LtAP WiFI connector labelling
Thu Sep 23, 2021 2:02 am
Don't know if it helps,
FCC Report on the LtAP
https://fccid.io/TV7LTAP2HND/Internal-P ... os-4173799
CuriousKiwi
Sat Sep 25, 2021 9:55 am
That would indicate that the MMCX connector next to "Antenna 1" is Chain 0.
I'll give it a go and see what happens
CuriousKiwi
Wed Sep 29, 2021 4:50 am
I've had a play and worked it out.
The onboard antennas are "Antenna A" and the MMCX antennas are "Antenna B"
Antenna and MMCX connector nearest the corner of the PCB are chain 1
krafg
Fri Oct 01, 2021 4:27 am
Please read this thread: viewtopic.php?f=3&t=173681
Regards.
Users browsing this forum: No registered users and 87 guests
