a6xa3
Routing Mark and Wireguard are not compatible (RC4)
Wed Sep 22, 2021 10:56 am
When I'm using Routing Mark with WireGuard - router looses returning traffic completely
If I use policy-based routing (in Routing-Rules), everything works flawlessly (new cool feature, maybe you can just add Address-Lists here as SRC/DST?)
The "strange" part I can see the incoming packet with the right SRC/DST, but it's not routed further when Mark Routing is used
If policy routing is enabled, I get the same packets and everything works as intended
Seems when I set up Routing Mark packets are arriving but never leave router and even router can't see them (same situation as it was with WireGuard packets in RC3)
anav
Re: Routing Mark and Wireguard are not compatible (RC4)
Wed Sep 22, 2021 11:12 am
Works fine for me, perhaps its the rc version you are using.
a6xa3
Wed Sep 22, 2021 12:29 pm
In RC3 WireGuard traffic were lost, now in RC4 it works but not with Routing Mark
Which config do you have?
Users browsing this forum: No registered users and 22 guests
