onlitec
VPN, the problem is that I do not access the remote network
Thu Sep 23, 2021 4:19 pm
Hello everyone I have the following scenario:
Linux Nethserver 7 virtual machine as AD and OPENVPN server router mode: VPN clients network: 10.1.1.0
Mikrotik Router RB750GR3 IP Network Gateway: 172.16.115.10
Netmask /24
I normally connect to the VPN, the problem is that I do not access the remote network, I found that I need to create a route to this network in Mikrotik, I have already followed several tutorials and nothing works.
Another question is: I have another local Nextcloud server and I would like users to access this server directly so I create a dst-nat directing to it on port 443, but the dst-nat rule doesn't work I already have 2 other NATs one for the alarm system and one for the VPN.
onlitec
Re: VPN, the problem is that I do not access the remote network
Sat Oct 09, 2021 3:02 pm
Somebody ?
Or in this forum does not help beginners?
erlinden
Sat Oct 09, 2021 3:13 pm
Can you please make a diagram of your network?
Besides, your config (posted between code tags) would be very helpful as well:
/export hide-sensitive file=anynameyoulike
Users browsing this forum: No registered users and 25 guests
