pcfixerjeff
Webfig not working without default bridge
Fri Sep 24, 2021 2:58 am
Hey Everyone,
I have just dusted off my RB3011 to get my home lab up to scratch and am having some issue after removing ports from the bridge.
I want to remove the default bridge and have each port dedicated to a different subnet/vlan. I have been banging my head against this all last night and this morning but as soon as I remove a port from the default bridge I am no longer able to access webfig or ping the device on that ports address. Oddly I am able to ping my workstation from the router but not the other way around.
Basically eth 9 is to be a management interface, on my management vlan
I have removed eth9 from the bridge and created a address for the interface / network, I have created a dhcp server on the interface and configure the network and dhcp scope. my workstation is acquiring a lease correctly from the router.
I am able to access winbox via mac-server on this interface as I have added it into the LAN Interface list but I am not able to access webfig, I also am not able to ping the interface.
I currently have the router setup with the default firewall rules, with the exception of modifying the ICMP rule to only allow input from the LAN Interface List. (it is all by default, icmp did not work on all either).
I assume that whatever is preventing ICMP from working is also why I cant access webfig, but might be wrong there.
I have ruled out layer 2 since I am able to access winbox mac-server and dhcp is working. the network is directly connected, and I can see the directly connected routes are populated. (I am able to ping from the router to the workstation, so that would suggest that actually layer 3 is fine.).
I configured a sniffer for icmp traffic on all interfaces and can see the icmp request, but not the responce. Something funky going on here, or maybe something obvious that I have glossed over. I appreciate any help you can provide.
Here is my config
# jan/02/1970 01:54:55 by RouterOS 6.48.4
# software id = IPZY-ASEY
# model = RouterBOARD 3011UiAS
add admin-mac=6C:3B:6B:FD:0B:C3 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=ip-pool-managment ranges=10.100.60.10-10.100.60.100
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=ip-pool-managment disabled=no interface=ether9 name=\
dhcp-managment
add bridge=bridge comment=defconf interface=ether10
add interface=ether9 list=LAN
192.168.88.0
add address=10.100.60.254 comment=ip-managment-network interface=ether9 \
network=10.100.60.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=10.100.60.0/24 comment=network-management dns-server=8.8.8.8 \
domain=(omitted) gateway=10.100.60.254 netmask=24
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
add action=accept chain=input comment="LAN: accept ICMP" in-interface-list=\
LAN log=yes log-prefix=ping-eth9 protocol=icmp
"defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
dst-address=127.0.0.1
in-interface-list=!LAN
disabled=yes ipsec-policy=in,ipsec
disabled=yes ipsec-policy=out,ipsec
connection-state=invalid
/ip traffic-flow target
add dst-address=10.100.60.100 port=0
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system logging
add topics=firewall
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=all filter-ip-protocol=icmp
Users browsing this forum: carcuevas and 26 guests
