j96j
Help me (noob) setup Qbittorrent Port Forward in Winbox
Fri Sep 24, 2021 6:17 am
Note: I'm a total noob in this. I've watched youtube videos on Port Forward tutorial, but I still can't successfully port forward. I actually was able to port forward 3 years ago, but somethings happened that made the Mikrotik reset, and now I can't port forward again (forgot the steps needed).
I'm trying to port forward port (ex: 65300) in Qbittorrent. So that my PC can be connectable to others.
My IPv4 address: 192.168.88.72 [Static IP]
IPv4 DNS servers: 192.168.88.1
My WAN [Public IP] address: 4x.xxx.xxx.xxx
I have no clue which address above that I need to fill in in the rules below
Here's what I have done:
In Qbittorrent settings, set port to 65300
In Winbox:
IP - Firewall - NAT:
New NAT Rule
Chain: dstnat
dst. adress: 4x.xxx.xxx.xxx
Protocol: TCP/UDP
Dst. Port: 65300
In. Interface: bridge
ACTION:
action: dstnat
to addresses: 192.168.88.72
To Ports: 65300
I'm unsure if I should fill in Src. Address, Src. Port, Out Interface, In/Out Interface List, etc.
Please let me know what I should've done.
Thanks in advance.
Here's screenshot of my NAT rules, the ones I added are number 18 and 19. Numbers 0 - 17 are made by a technician.
Also, the filter rules and connections. The technician is the one setting up the others. I'm only adding the qbt ones in NAT.
Users browsing this forum: Bing [Bot], martinsu, mode and 44 guests
