PisUshax
WiFi DHCP server with hotspot
Sat Sep 25, 2021 3:56 pm
Hi I am trying to create a network like the one in the diagram
I have a Huawei modem installed on the second floor near the cisco switch
I want to use the wifi of modem on the second floor and I have a MikroTik router which I will install on the first floor for wifi coverage of all building
I want to use the router for the hotspot and Radius server and I want all the users (first and second floor) to use the hotspot
I have wired connections in the whole building so I can use wire connections between my router and switch and modem.
I like to use Poe to power the router as well
hotspot and radius server is already setup
the problem is when I connect to the wifi of the modem it uses its own IP range and when I disable DHCP on modem devices cannot obtain IP from router
Users browsing this forum: AhmedQadir and 7 guests
