coreyclamp
CHR in AWS - Horribly slow
Wed Sep 29, 2021 1:25 am
I'm attempting to use a CHR in a fresh AWS environment. I have an extremely simple configuration on the CHR to enable masquerade and RDP port forwarding. The firewall is currently running as a t3.small instance (2 CPU / 2 GB). The machines behind the CHR are not able to download any files and web browsing is spotty - some sites seem to load fine and other partially load and eventually timeout. Response time seems to be fast until there is any significant bandwidth trying to get across.
Here is my config:
/ip dhcp-client
add add-default-route=no disabled=no interface=ether1
add dhcp-options=hostname,clientid disabled=no interface=ether2
add action=masquerade chain=srcnat out-interface=ether2 src-address=172.27.0.0/22
add action=dst-nat chain=dstnat dst-address=172.30.0.11 dst-port=3389 protocol=tcp to-addresses=172.27.0.20
add distance=1 dst-address=172.27.0.0/22 gateway=172.27.0.1
What am I missing here?
joegoldman
Forum Veteran
Forum Veteran
Re: CHR in AWS - Horribly slow
Wed Sep 29, 2021 1:34 am
Have you applied a license? I believe CHR will only route 1mbps or something very low without an applicable license added.
coreyclamp
Wed Sep 29, 2021 4:29 am
I'm running the 1G trial right now to no effect. Throughput is 100 Kbit at most with or without the license
Users browsing this forum: No registered users and 9 guests
