Can anybody here help how to put command similiar in routeros v6,
"ping x.x.x.x routing-table=route1"
in RouterOS v7
or other way to check ping / traceroute at diferent routing table
thanks..
if i use vrf parameter, the only option available is "main",Use the "vrf" parameter...
ip/route/add dst-address=0.0.0.0/0 gateway=x.x.x.x routing-table=route1 vrf-interface=interface_for_route1
